Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: Error mseeage Arrow 750
    Apr 2006
    I'm new to posting wonderd if anyone could help on fixing my Arrow 750?
    not shure on what controler I have.
    but i'm getting error 9181: y axis encoder phase signal fail.
    error 9183: y axis encoder reference signal fail.
    Any help would be helpful
    Mark
    Jul 2007
    Signal fail
    You have to find out what control is in your machine CT Or Acramatic?
    Apr 2006
    All the control panel says is cincinnati milacron
    the main board says spindex.
    does this help
    mark
    Jul 2007
    I think is a CT control, and is possible that water got inside the servo motor.
    Check all the plugs and if that don't work, you may have to take the motor apart to dried it out, just be careful not to brake any thing.
    masamayoa@hotmail.com
    Apr 2006
    Thank You Very Much !!!!
    that gives me a place to start.
    I'll check and let you know.
    Apr 2006
    Well no plugs no water in electric connections. but can't seem to get the back plate off motor. has a round cap on back plate took bolts out but just wiggles wont come of. so itook thbolts of back cover and that wont move at all.the motor is from control technoligy.
    Jul 2007
    did you get it out??
    Be careful not to mess up the encoder or resolver whichever apply .
    Apr 2006
    no luck i guess ill have to take the motor out to get it apart.
    Jul 2007
    "X" servo motor signal feed back
    Where are you located at ?
    Apr 2006
    the little town of bellevue mi
    Apr 2006
    Well finally got the motor out and it looks to be dry inside.
    Is there any way to check it?
    It's a DutymAx MS
    Model115MSA040200AG 220 volts
    Apr 2006
    Found the problem it seems my servo board went out Thanks for your help.
  • Page 1 of 2 12 LastLast
    1. ARROW 500 help
      By Lefty1961 in forum Cincinnati CNC
      Last Post: 11-11-2010, 07:42 PM
    2. Arrow 500 Air hog!!!
      By reflexx in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 09-25-2009, 02:27 PM
    3. Arrow 500 Drive Fault Error
      By macmub in forum Cincinnati CNC
      Last Post: 06-02-2009, 01:46 AM
    4. Cincinatti Milacron Arrow 1000 Tooling Error
      By peterlwoods in forum Forum Questions or Problems
      Last Post: 05-14-2008, 07:30 PM
    5. Cincinatti Milacron Arrow 1000 Tooling Error
      By david_culler in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 05-08-2008, 09:04 PM
