Results 1 to 6 of 6
Thread: Cincinnati Acramatic A950 Help
    Jun 2009
    UK
    Hi, has anyone successfully cloned an A950 Hard drive. I have cloned A2100 disks in the past without any problems.
    Any help would be much appreciated.
    Aug 2009
    Quote Originally Posted by mtcnc View Post
    I belieave the A machines required a different drive which makes it difficult, I do know some one that clone a "b" machine for our shop.
    Sep 2006
    A950's use 10 meg Winchester drives. You need the software disk to reload. Cincinnati does have a conversion kit now that uses IDE drives. These are much more reliable.
    I would imagine that cloning an A2100 is fairly easy since it is a Win NT OS. The Winchester drives, to the best of my knowledge were only used on UNIX type systems, though I don't know what OS Cinci used on the controls prior to the A2100, it's very likley that it is proprietary since they are all multi-processor controls. I think we counted 6-8 8086's on our T40's.
    Sep 2009
    Spain
    Hello,
    Yes, it is possible. I own had made it without problems. I copied all (sector-sector) from the original 250mb to 1.6gb one. And it is working (more than 6 months).
    Jun 2009
    UK
    Quote Originally Posted by lgg2 View Post
    Hello,
    Thank you for your post, What system did you use?
    Sep 2009
    Spain
    Hello,
    Simply under Linux,
    with the old disc plugged:
    dd if=/dev/[YourHDD] of=[WhatYouWant]
    with the new disc plugged:
    dd if=[WhatYouWant] of=/dev/[YourNewHDD]
    Search about disc clonning in Linux with Google. "dd" is an utility that comes in all Linux distributions. Work also with any LiveCD, without install anything in the PC.
    1. Cincinnati Acramatic A950 Help
      By newckl in forum Cincinnati CNC
      Last Post: 02-21-2009, 09:28 AM
    2. Need Help!- Cincinnati w/acramatic contols always going home
      By katsbobo in forum General Metal Working Machines
      Last Post: 01-30-2009, 01:17 PM
    3. Need Help!- Cincinnati Acramatic A950 Help
      By newckl in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 12-30-2008, 09:11 AM
    4. Need Help!- Cincinnati Acramatic A950
      By newckl in forum Controller & Computer Solutions
      Last Post: 12-30-2008, 05:29 AM
    5. Cincinnati 5VC750 acramatic 900V2
      By motordude in forum General Metal Working Machines
      Last Post: 02-06-2005, 11:37 PM
