| Cincinnati CNC Discuss Cincinnati CNC machines here. |
| We have this machine Hawk that had this power failure on the CPU and the PSU doesn't work anymore. After replacing the power supply with a new one, now the machine errors on the diagnostics with "nc engine base failed". After that on the screen with the report displays this: Bridge board RT Unknown Conv Servo Unknown High Density I/O Unknown Pendant Panel Unknown Real Time Processor Unknown There some info on this here, but the flash of the cmos is need it. Updating Acramatic 2100 (A2100) Maybe i can get a hold of hawk150 from a local company, and if there's a way to read the cmos from that computer and try to fix mine. Any help is appreciated......Thanks |
| We check the RT MB and found the CMOS to be corrupted. The way to fix this doing a hot-swap flash, but it has to be with a similar motherboard G7VP2. Since I couldn't get a similar board, I bought one from ebay. My only concern is "what if the cmos it was especially program for this machine" Any info on this please post or point to the right direction...thanks |
| Guys we really need your help. With the new motherboard, the machine now fails test on the Conv Servo . We already check the servo and is good. Check the motherboard in another lathe and we get the same error, so I think is the settings on the bios of the MB. Does anybody have the correct bios settings for this MB G7VP2. ...Thanks |
| hawke 150 Did you have the same probs before you replaced the power supply and did you use a power supply compatible with the one you replaced and have you tried to reseat all the computor boards.These things can cause some really weird errors to come up on the screen.Best of luck greg |
| Already try another rt mb from another hawk150 and it does work. That confirm thet our new MB is not working correctly because of the bios settings and i already play with this and stil can get the comunications to work and fails at conv servo. This week going to try move the bios settings but thru MDI option. |
| Machine is working again We email siemens and they send the configuration file back. Now the machine is working again. |
| g7vp2 cmos hello i am trying to fix my g7vp2 board as well but with no success. any chance you could send me the configuration information you had from siemans. regards mallardfizz |
| Shure can PM your email....... |
| realtime timeout hold fire i think i've cracked it. thanks for the reply regards mallardfizz |
#10
| I am struggling with the same situation too. Conventional Servo fails every time. I am trying to replace with a new motherboard(different brand). Can anyone here post the BIOS settings as a setup guide? Regards |
| Making Large "Turner's Cubes" on an Engine Lathe | widgitmaster | General Metalwork Discussion | 99 | 03-19-2011 07:59 PM |
| What is this called a "internal side crank engine" ? | Andy-7300 | I.C. Engines | 2 | 07-12-2008 02:04 PM |
| BattleAxe "aka" Ball and Chain "aka" the wife. | ZipSnipe | CNCzone Club House | 48 | 05-18-2008 10:53 AM |
| "Fixing" bent engine valve? | mmmjboner | Bending, Forging,Extrusion... | 18 | 07-16-2007 04:40 PM |
| Book "Elmer's engine" | Hans-Jürgen | Steam Engines | 3 | 07-23-2006 02:33 AM |
