Not knowing the machine, the APC functions are controlled by a "smart brick", an I/O device. It is probably located in an electrical box about 12" x 12" x 4". All the solinoid cables, switch cables etc. will be plugged into it. I have seen problems with vibration loosening connections. I have also seen heat being a problem. If all connections are good you will probably need to replace the unit.
LinkBack URL
About LinkBacks
