Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 04-28-2009, 07:10 PM
thouse is on a distinguished road
Need help with a 2100 control
I'm hopeing some one can answer this question.
Can the hard drive of a CinCi Sabre with the 2100 control be ghosted?
we seem to be running into loosing hard drives and the cost is getting pretty hard to cover.
I have been told that I can't ghost the drive due to Cincinnati's copy right protection.
Then I have been told you can but it is to difficult to do.
Can someone shed some light on this please.
thanks Troy
Old 04-29-2009, 09:32 PM
laka is on a distinguished road
It's very easy to do.
Get a copy of norton ghost, install it onto a bootable floppy disk, install a 2nd hard drive into your machine and ghost it.
Here is the technical article on it. It is recommended by Cincinnati. Even if you can't do it, you should pay someone to do it for you. It's well worth it.
http://members.shaw.ca/jasoncmckenzie/A21_049C.pdf
Old 04-30-2009, 08:05 AM
greg b is on a distinguished road
Hi laka is dead right,do it your self or better still get a computor geek to do it for you,I had simular probs with a cincinatti hawke/acramatic 2100 we used a 80g seagate hard drive and had it cloned off the oridginal,just make sure you dont have any viruses from other soarces that are on the oridginal because they can be transfurd to the clone.Actually i think seamans give permission to clone 1 copy,if you are going through these fast,I would think you may have underlying problems,may be heat or vibrations,I ended up putting cooling fans on my hard drive and power supply cabinet because they get very hot and it seems to have done the trick.Best of luck Greg.
acramatic 2100 control greg b General CNC (Mill and Lathe) Control Software (NC) 11 06-01-2009 04:33 PM
Acramatic 2100 control Help fmprap Cincinnati CNC 3 01-05-2009 04:47 PM
Need Help!- siemens acramatic 2100 control jptalon General CNC (Mill and Lathe) Control Software (NC) 1 11-22-2008 06:29 PM
Tree 250 2100 control mblazenby Tree 1 03-14-2008 02:28 AM
Acramatic 2100 control parts VSMIGuy General Metal Working Machines 3 02-19-2007 02:23 PM
