| Cincinnati CNC Discuss Cincinnati CNC machines here. |
| I have had a couple of decent hits with mine and thank goodness only the turret has moved,which is very simple but time consuming to realign.I have had a pretty good look inside where the head stock sits and I come away with the thoughts that if the turret is in alignment,then it would only be a matter of loosening the bolts that hold the headstock put a fixture in the chuck that holds a dial indicator and run it around the turret face and ajust as neccassary or if it has the same dowel pin method as the turret it makes it even easier.Hope this helps a little regards greg. |
| Hey while where talking cincinatti 150 hawkes would you by any chance be able to help me out with some imfo on the workings of the plotter as im missing the operators manual and i havn"t quite worked that part out yet,all the best Greg. |
| -------------------------------------------------------------------------- For FREE Cincinnati Technical support you can call 1-800-934-0735 Listen to the prompt for Cincinnat; then for Tech support/Parts. or... #4 wait for the ring to answer then #2 for Tech support/Parts. Greetings from: Tech Support MAG Global Services -------------------------------------------------------------------------- |
| Cincinnati Hawk 150 | madmike46 | G-Code Programing | 3 | 12-24-2010 02:51 PM |
| Cincinnati Hawk 150 | madmike46 | General CNC (Mill and Lathe) Control Software (NC) | 1 | 07-09-2007 11:32 PM |
| cincinnati hawk 150 | madmike46 | General Metal Working Machines | 0 | 07-01-2007 10:16 AM |
