Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 03-31-2009, 02:55 PM
Joefizz is on a distinguished road
Tool Drum On Arrow 750
Hi
Has anybody had trouble with the motor on the tool drum.
Mine dose not index to the next tool. The air blast works but the drum dose not turn. I taped the motor with a rubber hammer and it started working.
It worked for 2 days then stoped again. I think the motor has a dead spot.
Any ideas? Also can the motor be changed without droping the drum?
Joe
Old 03-31-2009, 04:42 PM
laka is on a distinguished road
We've had ours seize up once. It wasn't the motor but the bearings were bone dry. If you remove the round plate on the bottom center of the drum, look up and you can see the bearings. The only way we could get any lube on them was to press some grease in there as best we could. There is a nut that you can loosen with a spanner wrench what will back the bearings off a little to help get you moving. Dont forget to re-tighten. It is a pain the the butt job.
Good luck
Old 04-02-2009, 03:18 AM
James_jester is on a distinguished road
Hi, Check the proximity sensors on the far left hand side when the drum is at spindle, there's a small light on the sensor that flashes as each pocket position, if it isn't working, it may be just the sensor, it might be the actual motor that drives the cam and then subsequently the tool drum itself (try cleaning inside the open drum with coolant to ensure the holes nearer the centre of the drum are free from swarf etc (this save all the hassle of dropping the drum tool ring..
Have had a similar problem several times on my machines before, hope this helps..
James
Old 04-02-2009, 02:51 PM
Thanks for the insight I did both when it first happened.
It seams to stall only in one direction. So my sext step is to change the
relays in the back power box. I hope this works.
Joe
Drum Idea vacpress Musical Instrument Design & Construction 8 06-03-2009 04:37 PM
A2100 and tool probe Arrow brokenrinker Cincinnati CNC 4 01-23-2009 04:37 PM
DIY drum sander distan WoodWorking 3 04-05-2007 04:08 AM
milacron arrow 750 tool setting viper4297 Machine Problems, Solutions , Wireless DNC, serial port 5 09-15-2005 05:23 PM
