Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 02-11-2009, 07:28 PM
chaz6966 is on a distinguished road
arrow 750 control techniques controller
in the directions for the control it talks about fnc downloading to the machine.
i am using bobcad-predater software and it has dnc to download to themachine.
is there a difference between fnc and dnc ..
has anyone used this control and what would be the best way to get programs tto it.
manual says i need cnc_com on dos. i have it but when i open it and then run predater to send program i get an error , unable to open communications device.
if i just use predater it says sending program and it seems to be on screen of pc but nothing at control.
thanks for any replies, i bought this mill and as you can see i dont know what i am doing.........
thanks, chuck
Old 02-18-2009, 01:08 AM
LeftCoastCNC is on a distinguished road
I just use CNC_COM to rebuild the software when it dies. To transfer your files use your CAM software. You need to prep the machine to receive the program BEFORE you sent if from your PC.
In Auto mode, use soft keys to get --> Background Edit -->File Ops --> Load From (I use RS232A), then type in the file name you want the new program stored as on the control and hit enter. The machine is now ready to receive the program from your CAM software. If you are still having trouble you might need to configure your communications (Baud Rate, Parity...) so they are the same on the machine and CAM software.
Good luck!
Kris
FNC4 Control Techniques dhenderson Want To Buy...Need help! 3 07-25-2010 11:51 AM
need help Arrow 500 FNC control gronux Cincinnati CNC 0 02-08-2009 10:56 AM
Offline control unit from a cincinnati Arrow Jimthefish Cincinnati CNC 5 10-23-2008 09:59 PM
Information about Control Techniques VC55 BillTodd Phase Converters and VFD 0 08-29-2008 08:31 AM
Control Techniques FNC-4 controller rbrougha General Metal Working Machines 0 06-09-2004 10:29 AM
