| Cincinnati CNC Discuss Cincinnati CNC machines here. |
| Dear Friends, It's really amazing for me when I turn On the machine all drives in back of machine are blinking but when I push the bottom to start the machine there no reaction(all emergency bottoms are off). My control system is Arrow 750(I have tried to find solution by other topics but no result) Please send me your suggestion. Thanks in advance for your helpful reply. Have a Nice Year in 2009 Best Regards, Jalal |
| it wouldnt be the first time that button stoped working. try to measure it with an ohm meter. also check circuit breakers. |
| I measured but there was no sign of starting ! But We are sure that drives are OK so there must be some problem in other parts referring to drawings we couldn't find a solution. Thnx Jalal |
| if there is absolutely no sign of starting, then there is problem with power. check voltages on all power supplies. check voltage on wire, that connects to power button, under operator panel. then follow that wire, by drawings until you get to defective component. is possible, that your CRT stopped working? i saw your topic reffering to that problem... drives normally get power when controller boots, or when you switch on the main switch? |
| I will check and let you know the result. Thanks very Much. Jalal |
| Newbie- one start or two start lead screw | Pinhead | DIY-CNC Router Table Machines | 5 | 11-22-2008 11:32 PM |
| Sodick EDM machine Model A7C with MARK XI Control - Start up problem | rajappa | EDM Machines | 9 | 07-20-2008 11:08 PM |
| Single start vs double start ballscrew. | darik | Linear and Rotary Motion | 13 | 03-21-2007 08:53 PM |
| Bridgeport Discovery 308 W/SX-15 Control Start up disk needed | Richardd | Bridgeport and Hardinge Mills | 1 | 07-10-2006 09:07 AM |
| Help - Spindle Will Not Start from NC Control | CSE | Bridgeport and Hardinge Mills | 7 | 05-24-2006 12:56 PM |
