Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 12-06-2008, 09:56 AM
gabby is on a distinguished road
help to get out of crash mode
Hi can anyone offer any help I've ran the turret into the spindle and cannot power up machine. Error message on screen realign turret. But I cant open the door or power up machine.
Old 12-06-2008, 02:02 PM
mte.jalal is on a distinguished road
You can use some short circuits, check the electrical drawings it so easy !
Old 12-06-2008, 03:24 PM
gabby1 is on a distinguished road
hi thanks for the answer but im no electician and not too hot on electrcs either. Is there any way from screen to open door or move turret. I can turn machine on machine loads up and screen comes on but an alarm comes up and wont let me turn on power to move anything
Old 12-08-2008, 12:12 AM
KLUCAS4 is on a distinguished road
You may have to hold in the power on button while handwheeling the tuuret away from the chuck. We have a Republic Lagun MIll with the 2100 control on it and on occasion when it overtravels In any Axis you have to hold in the power button then move the axis away from the overtravel state.
Old 12-09-2008, 05:38 PM
laka is on a distinguished road
If this is on a Hawk machine, you need to open up the back cover (not the electrical cabinet, but the other large cover on the back behind the turret). Inside there is a proximity switch that when the turret it pushed back too far (from a crash) it will trigger this switch to shut off the power. You can try loosening the switch and moving it away to release it. This should help.
Old 12-09-2008, 08:28 PM
Stickerman is on a distinguished road
To unlock the door look at the mechanism that holds the door closed. There will be a plug on top with a slot in it that needs to be unscrewed. There might be a small t-shaped tool tied to the box there that is used to unscrew and unlock the latch. Once you take out the plug use the tool/standard screwdriver to turn a small gear inside to unlock the door.
Then you can look below the turret for the switch.
There are eight bolts that hold the turret on my Falcon 200. Of course five of them were stripped when I got the machine.
When people say to call Maintenance Technologies to ask for help.. listen. They will talk you through just about anything to try and get your machine running.
Old 12-11-2008, 04:33 PM
thanks guys got machine going Im gonna ask for two salaries now operator and maintenance lol you all have a great xmass
I need a crash course!!! dpotts Diemaking and Diecutting 4 09-03-2009 08:09 AM
New Machine Build- spline mode nurbs mode cooltool CamSoft Products 4 03-10-2009 03:03 AM
What is - Torque Mode? Position Mode? Speed/Velocity Mode? sunmix Servo Motors and Drives 25 10-26-2008 04:53 AM
Need Help!- sl-30 crash bowhunter Haas Lathes 5 10-14-2008 01:53 PM
I need a crash course!!!! dpotts Moldmaking 0 03-31-2007 12:48 PM
