Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 12-02-2008, 12:51 PM
matthew6060 is on a distinguished road
Realtime timeout!
We are running a '97 sabre 2000 and if it is pushed faster than 140ipm it will fault with a "realtime timeout." anyone have any ideas? its gettin a bit old having to go so slow...
Old 12-02-2008, 06:35 PM
mallardfizz is on a distinguished road
realtime timeout
hello the error you are seeing is related to the realtime motherboard - this is the one on the right hand side of the control.it probally only has 4Mb of ram on the board.try adding more RAM.You will post an alert when starting up the control.this states you now have more realtime memory than you paid for - press clear alarm.if this doesn't cure it the only solution I know of would be to change the realtime board.I don't know of anywhere but Cincinnati to buy these from and they are expensive.if anybody has an alternative i would very much like to here from them.regards Mallardfizz
Old 12-03-2008, 01:57 PM
mr fizzter, thanks for the reply... we will be trying adding ram soon...
Old 02-21-2009, 09:42 AM
robert.cichon is on a distinguished road
A2100
Only alternative to paying for an upgrade is to find a product key from a machine which has this upgrade and to re-idenitfy the control serial number attached to the product key with the upgrade you want.
Convoluted but it will work.
And it will enable every upgrade prior to the last one (attached to the product key). The bad side is if you purchased an upgrade not included with the hacked product key, you will lose it.
Buy the upgrade from MAG.
Old 02-22-2009, 12:33 PM
i don't follow you exactly. i think i can understand what you mean but i have no idea how this could be accomplished. please explain.
Realtime implementation in EMC ChandlerBing LinuxCNC (formerly EMC2) 4 02-28-2008 04:26 PM
XR demo timeout clay allen OneCNC 7 01-14-2007 11:21 PM
Change timeout kodalo PicStep Controllers 0 10-05-2006 02:24 AM
