Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 11-22-2008, 09:11 PM
advt001 is on a distinguished road
drawbar
Has anyone had to replace the disc springs on an arrow 1000 drawbar?How hard is the job to do?I cant get a mechanic in for 2 weeks so I'm going to have to repair it myself.Thanks again for all the advice.
Old 11-23-2008, 09:19 AM
Rick Kight is on a distinguished road
advt001
Have not replaced due to failures but they have to come out on a spindle rebuild which we have done numerous times over the years. You need to make a tool to keep the draw bar from turning when you unscrew the big nut / ring on top of the assembly. The tool is nothing more than a big screwdriver like tool , the top of the draw bar is slotted. the big retaining nut / ring has a couple of set screws that you need to lossen before it will come off. Be sure to measure from the top of the draw bar (slotted part) to the top of the retainer as this diminsion needs to be re established when you put things back together. The air cylinder that opens the draw bar works off of the top of the nut / retainer, that is the reason for getting the measurement. We lube the spring washers with a dry film lube when we ressemble. That is about it.
Good Luck
Rick
Old 11-23-2008, 06:49 PM
Thank you, Rick
Drawbar force (MT3 & R8) The Blight General Metal Working Machines 2 02-15-2009 12:46 AM
Problem- VF4 - DRAWBAR ErikVF4 Haas Mills 2 06-11-2008 02:34 PM
X2 R8 Drawbar length??? maxboostbusa Benchtop Machines 1 10-04-2007 11:09 PM
Where to buy a drawbar? MrWild Bridgeport and Hardinge Mills 3 07-31-2006 07:44 PM
Automatic Drawbar Help Barry_ward General Metal Working Machines 10 06-25-2006 07:57 AM
