| Cincinnati CNC Discuss Cincinnati CNC machines here. |
| Hi, I'm really in trouble, Please somebody help me! I have separated the control(A2100) H.D.D in order to make a clone from hard disk then after connecting the hard again to control while starting windows Blue window with full of errors comes meaning Failed to Boot ! However I want to see if there some input device like CD-ROM or Floppy in that case I would be able to repair the boot. Do you have any suggestions ? Thanks in advance. Jalal |
| Depending on what you did to clone the disk, you may have changed the boot record of the drive. Sometimes just plugging in the drive to another computer will do this. If you can get into dos, possibly by loading the NT setup floppies you may be able to get to the recovery console, ifso you can type fixboot and it should ask you if you are sure you want to rewrite the boot table. It's been awhile for me, so I hope I didnt miss anything. Fixboot does not format anything, so it shouldnt mess anything else up. |
| If you are cloning a hard drive on a A2100 system, always do it from the A2100 system - don't put the master hard drive in another computer or this will happen. You can also try and copy the contents of the hard drive to a fresh-formatted in NT bootable drive. If the boot sector is damaged, the rest of your data is usually OK. |
| Ron Thanks for your given nice information. There is big problem I can't install a floppy drive to control, I could find the port but I don't have the cable that connects to that port as you know it's not an standard slot if I find the pins drawing I might be able to make a cable myself, also if you do me a favor and show me how the floppy is connected to control I would be so thankful. Thanks in advance Jalal |
| Can you boot from a USB device? Get a memory stick and format it transfering the system files to make it bootable. From the BIOS make sure that "other boot devices' is selected. That should get you round the floppy problem.
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
Can you bypass the machines proprietary connection and connect directly to the motherboard? I have never opened that box up personally, so I do not know whats in there. Rob |
| hello! this is my first post here.. I had the same problem with a2100 hdd as mte.jalal. here is the solution: when win xp, or similar, detects an older version of ntfs file system, it automaticaly updates it during boot. that updated partition is not readable anymore for win NT, that acrimatic uses. you get blue screen during boot. you have to format partition under winnt with old version of ntfs, or format it to fat16 system under control panel->admin tools->computer managment->disk managment under winxp. then just copy files, wich you backed up earlier with windows explorer back to new hard drive. it work for me, it should to you too. |
#10
| yes, of course you have to back up data first! what i am saying is, if you make an image with norton ghost, acronis TI,... when you restore that image to another disk, it wont boot, because winxp changes ntfs file system. you have to manualy copy files from a2100 disk to your hard drive in computer, and when restroing data first make fat16 partition and then copy files from your hdd back to new. I tried fixmbr, and some third parity boot tools, but none worked. |
#11
| thank a lot, you seem to more professional. Unfortunately I have sold the machine and no i one with other control working with Acramatic 7500 it's not computer based. But I'm so happy to learn that solution from you. I hope others can solve this problem by your given solution. Thanks so much. Jalal |
#12
Hello! this is my first post sorry for my inglish i`m from argentina and dont speak very well. i need clon the hard disk of A2100 for my work because we need copy of this hard disk for future repairs..i conect the hdd of cnc in my pc with slave and see the folder "mustang"...is this the software of cnc???..Then it is possible to copy this folder to another hdd with windows nt already installed??the operating System work fine in the cnc??But I practise another method serious feasible?Is possible clon the hdd in windows xp??I test with norton gost 2003 but dont works..other software for cloning for windows xp???tnks!! sorry again for the bad english! PLease ANSWER TO MAX_JASINSKI@HOTMAIL.COM Thanks!! |
| Tags |
| ..., boot fail, starting machine |
| Crusader-M Duart failed but..... | MrWild | General CNC (Mill and Lathe) Control Software (NC) | 3 | 08-15-2008 07:16 AM |
| Tried to buy a HF X2 yesterday. Failed! | tooManyHobbies | Benchtop Machines | 8 | 03-11-2008 07:00 PM |
| X axis transistor failed...AGAIN | Mr. Technical | Bridgeport and Hardinge Mills | 18 | 08-21-2007 07:16 PM |
| Boolean difference failed | chetosmachine | Rhino 3D | 8 | 06-12-2007 06:24 PM |
| Failed transformers? | Jetlag | General Electronics Discussion | 2 | 09-09-2005 03:50 PM |
