| Cincinnati CNC Discuss Cincinnati CNC machines here. |
| Arrow 750 - Only 40 volts going to my control power supply On our Arrow 750, I am only getting 40 volts to the plug that goes into the power supply on the control - should be 240 volts. Any ideas? |
| You have to check the origin of the 240v, if you have a modern sensitive VOM, then often leakage/capacitive coupling can give you a AC reading, but due to the fact it is leakage, it will not support any kind of current. If this is so, you may simply have a fuse O.C. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| I've been trying to track it down as best I can. I guess I'll just keep at it. Actuall one side of the plug is at 120v, and the other side only has 6v and when I test them together I get 40v |
| If so you have a blown fuse on one leg. Al.
| To machine ground. I've looked through the electrical schematics and i've traced it back to a "45 Second Switch" but I can't seem to find this so-called switch. It's not like we've ever had to wait 45 seconds for the power to come on before. I had Cinci tech support on the phone today, but it was the end of the day and I'll have to call back on Monday. I thought I'd get some ideas here and play with it some more on the weekend. I've sure learned how to use a multi-meter anyway! And I haven't even zapped myself yet |
| Cincinniti Milacron-arrow 750 Control Card | camay | Servo Motors and Drives | 2 | 05-14-2008 07:33 PM |
| DC speed control as power supply for g320? | DennisCNC | Gecko Drives | 5 | 02-19-2008 12:43 PM |
| control transformer to power supply? | bobleecnc | General Electronics Discussion | 8 | 05-19-2006 09:42 PM |
| Boosting three-phase 240 Volts to 480 Volts | Old Car Guy | Phase Converters and VFD | 6 | 05-01-2006 10:27 AM |
| Power Supply from a computer power supply | jmytyk | General Electronics Discussion | 21 | 01-11-2006 03:56 PM |
