Results 1 to 2 of 2
Thread: cinn maxim 630 pallet offsets question
    Mar 2004
    indianapolis ,Indiana
    we just purchased a used maxim 630 and i'm having trouble getting the pallet offsets to work. I can set a fixture offset for pallet 1 but having trouble activating the offsets for pallet two.
    Sep 2009
    Spain
    Hello,
    It is a bit complicated. In a two only palet system:
    - In ProgramMagnament->DirMgnt You must assign (modify) the ID column to match a program with a palet number. The others programs must remain as -1
    - Inside the program, in EditMode, You must begin the program with a :G129PxCy x=Palet number y=Offset table (see below)
    - In OFFSETS (a bit nasty inside this) there will be through SELECT touch 4 options. Only 3 are needed. First select the top option. In this choose the palet number and modify the STATUS to PRESENT. With the wanted palet highlighted, go to SELECT and touch on the second option. You must select a table changing the STATUS also to PRESENT and the ID to match the palet number. With the wanted table highlighted, go to SELECT and choose the 3er one. Now You have several rows. Fill the needed rows. I usually fill one row per 90º angle (0º 90º 180º 270º) less o more (you will see how many you need). Several offset per angle are allowed.
    - Back to the program, Edit Mode, You can use that offsets with G0,G1,G2 or G3 interpolation. Are modal until ESC is pressed. The form is (i.e.):
    :G90G0X0Y500Z500B90H7S250M3M8
    -If persist ProgramID<>PaletID, try in MDI G129PxCy to make match the correct palet.
  1. Question on using g10 for work offsets HMC Fanuc
    By Shotout in forum G-Code Programing
    Last Post: 06-25-2008, 04:49 PM
  2. cinn milicron maxim 630
    By PETE1968 in forum Mastercam
    Last Post: 12-18-2007, 10:19 AM
  3. cinn milicron maxim 630-arcramatic 950 control
    By PETE1968 in forum General Metal Working Machines
    Last Post: 12-17-2007, 08:44 AM
  4. Question on setting up lathe tool offsets
    By SRT Mike in forum General Metalwork Discussion
    Last Post: 10-25-2007, 09:23 PM
  5. very basic question about ID boring offsets
    By juxtoposed in forum Haas Lathes
    Last Post: 06-26-2007, 02:23 PM
