Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
  #25   Ban this user!
Old 12-02-2008, 10:11 PM
KLUCAS4 is on a distinguished road
I have an original program from Cincinaati that allows you to use the hyper terminal, drip feed and everything. Its pretty cool you just start the DNC program at the pc them use terminal to send or recieve programs right from the control to any drive from your pc. It also when you run it in dos has the ability to drip feed. I got it from Acramatic Control User Group on Yahoo they upload files for all to share. Its the way to go with this control for DNC and this uses your RS 232 port. Email me And I will try and help with your other issues. I have about 13 yrs working with that control.
  #26   Ban this user!
Old 12-02-2008, 10:32 PM
Forgot to mention I have the pin ups for this control. Also using hyper terminal allows you to increase your buad rate more comparable to a modern control. Fixture offsets are at Mach Setup.
Newbie- How to cut jobs longer than the table using a gerber saber w/artpath Cocoa Astros General Metal Working Machines 2 08-13-2008 10:02 AM
gerber saber 408 schantal Commercial CNC Wood Routers 3 10-19-2007 04:52 PM
¿Se puede saber el torque de un motor sabiendo otras características del mismo? postman Spanish CNCzone 1 06-07-2007 01:35 PM
light saber go-off-road Mini Lathe 6 09-08-2006 11:43 AM
4th axis add on to a shop saber dac DIY-CNC Router Table Machines 0 08-22-2004 09:58 PM
