Results 1 to 3 of 3
Thread: Acramatic 850 alarm help!!
    Dec 2010
    Exclamation Acramatic 850 alarm help!!
    My company has a 1990 Sabre 750 with the Acramatic 850 control. It is a machine we acquired about a year ago, but have not used it. Recently we set it up and got it going and every thing seemed to work well. I started a job on the machine and did some facing and shoulder milling it did well. I went to drill some holes and that is when i got the alarm. It would start the drilling cycle and drill about .1 - .2 in deep and throw alarm 19330 Clamping / Mec failure. I can't find this alarm in any of the manuals. Does anyone have experience with this or know what may be the cause of this alarm.
    Thanks for any help.
    May 2010
    I have not touched this machine in many years this may help or maynot. Sounds like clamping mechanical failure. One the clamping senors may be slightly off or a loose wire or broken wire. You can remove the cover of the spindle and i believe there is some small red lighted sensors on the front or side. One for unclamp and one for clamp. They may need adjusted.
    Feb 2011
    IIRC you have a 4th axis clamping/unclamping signal not getting back to the control.
  1. HELP CINCI 630 ACRAMATIC 950 AXIS OT ALARM
    By dvolgstadt in forum Cincinnati CNC
    Last Post: 05-24-2011, 02:36 AM
  2. Problem- Daewoo DMV3016 Mill Alarm (Spindle tool clamp/unclamp alarm)
    By nickhough in forum Daewoo/Doosan
    Last Post: 05-09-2011, 12:22 PM
  3. Replies: 5
    Last Post: 12-18-2009, 05:07 AM
  4. Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm
    By doubleeagle in forum Daewoo/Doosan
    Last Post: 06-12-2009, 04:15 PM
  5. CICINNATTI MILACRON - ACRAMATIC 2100 ALARM-APC RACK 0
    By CHANDRU in forum Cincinnati CNC
    Last Post: 05-15-2009, 09:02 AM
