Since you mention you have already sent a simodrive in for inspection, I am assuming you are referring to the Drive's power supply (there are also other power supplies in the machine not directly related to the Axis drives). The drive power supply unit will be mounted with the Drives, connected by a DC BUS (2 heavy wires or connectors that bring DC power from the power supply to each of the spindle and axis drives.)
In most Cincinnatis, the power supply is mounted on the left, followed by the spindle drive(s), then axis drives. It should be pretty obvious which is the power supply, but if in doubt, look at the label on each of the drive components.
LinkBack URL
About LinkBacks
