Results 1 to 5 of 5
Thread: A2100 control - Format error message
    Jun 2011
    UK
    I am getting a message box displayed :
    Format Error
    Error formatting cycle message. ID : 0x280001
    This comes on repeatedly after power-up. It can be cleared (eventually) by repeatedly touching the "OK" box on screen - though after pressing this the normally blue box goes grey rather than clearing.
    This message has started coming up after the problems I described earlier where the main circuit breaker tripped repeatedly due to an X axis servo wiring fault - the control being shut down without having saved data.
    Could anyone suggest how to cure this, please ?
    Regards,
    Nigel Barraclough
    Jun 2011
    UK
    I spent a bit more time on the machine yesterday, so a bit more information.
    The messages that appear are not all the same - the last digit of the address varies. I have seen 0x28000A and 0x28000B as well as 0x280001 noted in the original post.
    The 0x280001 message comes up when I press the "Mech align" button. IIRC there used to be an information message came up prompting the carousel to be positioned at station 1 before confirming using the "Mech align" button.
    I can align the axes & the toolchanger and then clear the error messages, so am assuming that I have some corrupted message files somewhere ?
    The control appears to be operating from a 1GB Compact flash card - I can see no HDD. The card shows a directory called "Mustang" - is this the CNC operating system ?
    Can anybody point me in the direction of the message or info files, or suggest how I can repair or reformat the files, please ?
    Regards,
    Nigel B.
    Oct 2008
    uk
    hello
    i think the flash card replaced the original hard drive (probably by me). i think you might need a replacement or the software reloading.
    regards
    mallardfizz
    Jun 2011
    UK
    Hi Dick,
    Your name is pencilled on the electrical schematic along with a mobile number. Can I contact you on that number ? (ends 594)
    The machine is the Sabre 750 that was in Guernsey.
    Regards,
    Nigel B.
    Oct 2008
    uk
    yes you call me on that number.
    regards
    Dick
    (mallardfizz)
    1. Problem- DX-32 Control, Error Message, No Clue!
      By minton in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 07-29-2011, 11:34 PM
    2. A2100 Arrow 500 Error help
      By kentsui in forum Cincinnati CNC
      Last Post: 10-31-2010, 01:44 PM
    3. Arrow 750 with CT control error message 9036
      By DEAN-O in forum Cincinnati CNC
      Last Post: 08-24-2010, 01:13 PM
    4. Newbie- GE control error message
      By Good_GuyMN in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 02-14-2009, 02:22 AM
    5. Problem- A2100/NT boot error
      By kentsui in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-14-2008, 05:44 PM
    Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
