Results 1 to 8 of 8
Thread: Pull Stud Socket for Cincinnati Arrow 500?
    Mar 2012
    Ok, so I have figured out which Pull studs I need
    The CAT40 Long Body Pull STuds from Nordicor
    CAT-40 Cincinnati Retention Knobs
    However, they are sold out of their pull stud sockets.
    I came across Maritool, and am trying to figure out which of their two CAT40 Pull Stud Sockets I need.
    The PSW40
    PSW40 pull stud socket for CAT40 or BT40 MariTool
    or
    The PSW40M
    PSW40M pull stud socket for CAT40 and BT40 MariTool
    Oct 2011
    I just use a 3/4" wrench.
    Mar 2012
    A 3/4" wrench? that could work, but what if I needed to tighten the pull stud to a specified torque?
    Apr 2004
    These guys make the socket as well:
    Techniks Toolholders for CNC Machines and CNC Routers – Magnetic Workholding, Lifting Magnets, ER Collets, CNC Tooling, Deburring Machines
    Very good habit to use socket and torque wrench. I believe 85 ft/lbs is what is recommended.
    Feb 2011
    Thanks for the link.
    Mar 2012
    lake,
    We have tried ordering stuff from Techniks before, but they only sell to distrubuters, meaning we can't order from them. Do you know of another site that we could order a socket from? Perhaps one from the two links from Maritool I suggested in my prior post?
    I still haven't gotten word on which of the two, the PSW40 or the PSW40M I need to use...
    Apr 2004
    The PSW40 looks like the one you need if you are using pullstuds/tooling with 5/8" UN threads. The PSW40M looks like it's for metric threaded pullstuds/tools which arent as common.
    Mar 2012
    Looking at it that way, I bet the "M" stands for metric... Never thought of that.
    Thanks for everyone's help!
    1. Pull stud size
      By chevalier in forum Syil Products
      Last Post: 12-01-2011, 06:32 PM
    2. Need Help!- Pull stud?
      By Ph2011 in forum Bridgeport and Hardinge Mills
      Last Post: 06-12-2011, 08:07 PM
    3. need help with pull stud
      By pper in forum Tree
      Last Post: 05-23-2011, 12:02 PM
    4. lagunmatic 320 pull stud
      By topcnc in forum Knee Vertical Mills
      Last Post: 03-20-2011, 04:09 PM
    5. Arrow 500 SK40 Pull Stud
      By NanoMagnetic in forum Cincinnati CNC
      Last Post: 08-26-2010, 11:54 AM
