Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: NCA - Transformer Overtemperature - Arrow 1000
    Mar 2012
    Hey,
    I am getting an error message whenever I try to turn on the machine power of our CNC machine.
    I've attached an image of the message below.
    Could anyone try and help me figure this one out?
    Attached Thumbnails Attached Thumbnails NCA - Transformer Overtemperature - Arrow 1000-error.jpg
    Dec 2003
    Many transformers have temperature sensors buried in the winding, either the sensor is defective, open or the TXfr is overheating?
    If the transformer is powered up when you switch on the machine then it would not be an overheat problem.
    Mar 2012
    How would I check these things? I'm new to the CNC machine world.
    Dec 2003
    First check the transformer for overheat, it is usually a large supply transformer in the enclosure or attached to the machine, you really need the machine schematics to locate any sensor wiring, otherwise it is just a case a tracing it out, look for a pair of small conductor wires leaving any large transformer.
    Mar 2011
    Is this is a machine you just purchased, if so, did it come with the factory transformer? If it did, you need to hook up the overtemp signal wires which were disconnected to ship it to you.
    If the seller kept the transformer (which happens on most used Cincinnati's I've come across), you will need to jumper out this signal to get the control to clear the alarm.
    If you check your prints they will tell you what pin/plug needs to be closed to bypass this signal.
    If you've been running the machine for a while and this just came up, as Al indicated, you have to look at the transformer to ensure it is not faulting for a reason.
    The more information you give about the history of the fault when posting, the easier it is to point you in the right direction.
    May 2012
    Hi, I find this forum is very helpful. I have the same error message but it's not on all the time. It seems like if the machine is off for awhile then the error appears but if it's running often, then the error disappear. I don't have the factory transformer. I hook up the machine to a 208V. Can you help me? Thanks
    Nov 2007
    Start looking around inside the power Cab and on the transformer case itself for some type of reset switch or tripped breaker. I do not advise you to even open the Cab unless you have some experience with electrical systems. If you have given it plenty of time to cool down and are still getting this alarm then something like a switch or breaker needs to be re-set or worse. I have two Arrow 750's both have external power transformers. I have never seen this error but will take a look at mine tomorrow and see if I can find some type of re-set.
    May 2012
    thanks u overflo . I check but cant find the problem. Please help me out.
    May 2012
    Quote Originally Posted by dreygata View Post
    Hey,
    Have u fix the problem? i have same thing on my machine. need help, thanks
    Dec 2003
    Obviously the controller has to obtain the information from some source such as a sensor in order to display this message, you need to examine the electrical prints to ascertain which input has a temperature sensor or similar, of some sort and trace it back to the source.
    Mar 2011
    Dukepho,
    Your description that running for a while will make the alarm go away doesn't make sense. If the Overtemp signal from the transformer is missing, the machine shouldn't be able to run at all. Are you sure you have the same alarm as the original post?
    However, based on the original post issue, the following are your most likely scenarios:
    1) your transformer has a similar overtemp switch, and your transformer is overheating (or the overtemp switch faulty and is tripping when it shouldn't)
    2) You are not using the input and there is a jumper closing the circuit. Check your jumper to ensure it has a good connection.
    May 2012
    Im new to this. Do any know who can come fix the problem? i live is Santa Ana, Ca. 714-548-5839. Thanks for all ur help. This is a overtemp switch?
    Attached Thumbnails Attached Thumbnails NCA - Transformer Overtemperature - Arrow 1000-pic.jpg
  • Page 1 of 2 12 LastLast
    1. Arrow 1000
      By Dixieplastics in forum Cincinnati CNC
      Last Post: 03-13-2012, 08:37 AM
    2. Arrow 1000 not powering up
      By Arrow eeyore in forum Cincinnati CNC
      Last Post: 01-26-2012, 02:51 AM
    3. Need Help!- mastercam x5 on arrow 1000
      By getting better in forum Mastercam
      Last Post: 10-05-2011, 09:58 AM
    4. Need Help!- Cincinnati Arrow 1000 Not Starting
      By zephyrmachine in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 06-30-2010, 11:29 AM
    5. TPA Question Arrow 1000
      Last Post: 05-19-2010, 10:59 AM
