Results 1 to 1 of 1
Thread: Problem with Cintimatic Milacron 7VC-750
    Feb 2012
    United states
    Exclamation Problem with Cintimatic Milacron 7VC-750
    Need help. Problem is on a Cintimatic Milacron 7VC-750, Acramatic 850 machine. Here is the problem:
    When all of the axis are zero'd initially, the tool changer will operate correctly. If the table is moved again in any direction, the tool changer will not function and the machine will not function at all after that unless it is shut down and power re-applied. The Sector Master Module Error Code is A0. The cluster address is 04. I would certainly like some input on this and what area I should be looking in. Thanks
  1. Replies: 3
    Last Post: 09-05-2011, 08:19 AM
  2. CINC MILACRON ACRAMATIC-850 ALIGN PROBLEM
    By keyancnc in forum Cincinnati CNC
    Last Post: 01-25-2011, 12:21 PM
  3. Milacron Arrow 750 machine alignment problem
    By LG3 in forum Cincinnati CNC
    Last Post: 03-30-2009, 06:57 AM
  4. Need Help!- Cintimatic AC5 N/C
    By JILcoRICH in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 01-23-2009, 09:47 AM
  5. Need Help!- milacron 7vc
    By kirkkks in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 07-14-2008, 08:32 PM
