Your repair tech should be able to more fully answer these questions for you. Does the machine have an RS-232 communications port? Are the port settings correct in the machine parameters? Does the RS-232 communications function properly? As long as the answers to all the above questions is yes, you should be good to go.
LinkBack URL
About LinkBacks
