I think you will find the under voltage problem with the drives is because its all to do with the batteries being dead on your realtime and workstation board.The process starts here and I think you will find you may need to get new batteries installed and get the boards reconfigured.Theres a couple of guys on this forum that should be able to help you with that,best of luck.
LinkBack URL
About LinkBacks
