When you tried using the mouse, did you try plugging it directly into the ps/2 port on the CNC, or the port mounted by the op station (which is just using a long ps/2 extension cable to carry the signal).
I know a standard mouse cable won't be long enough to watch on the op station monitor, but if this works, you can pick up a ps/2 extension cable to use until your new op station arrives.
If you are buying the LCD upgrade from Siemens, it should come with the full op station assembly including the touch screen and KTI board, so I wouldn't spend a lot of money trying to get your current setup working if you are planning to purchase the upgrade anyway.
LinkBack URL
About LinkBacks
