Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 01-06-2012, 07:53 PM
67chevym is on a distinguished road
Question need help with Cincinnati Sabre 750 tool length
need help, i have got a used Cincinnati Sabre 750 CNC with
a Acramatic 850 CNC Controller.up and running ,and i am trying
to understand how to program it ,i got it to home out and
made a fixture offset home with h1,can get it to go,but can not get it to pick up the tool length ,i am in mdi,and did this :t1g90g1f50h1zo$
i set the z plane at 12.00"
i set the tool length at 2.00"
and it still will go to 12."
can some help me understand what i did wrong?
thanks
Old 01-14-2012, 07:37 AM
Ron P. is on a distinguished road
Here are the very basic things to answer:
Do you have the tool length in the tool table?
Did you put that tool into the spindle with an M6?
The correct Tool pocket number has to show on the CNC or it won't register the length.
You don't use an H word to activate tool lengths on an A850 like a Fanuc does.
Remember, for the A850, the tool length in the table is very close to the length you'd measure from spindle face to tool tip with a scale.
HTH
Ron
Old 01-14-2012, 10:51 PM
Smile Thanks
Thanks,
i have 5.5 in the tool table,
i have h1 set to x 12. y 10. z 10.
then i go to mdi,
put in :t1m6g90h1g1f50x-3.y-3.z3.$
but it still goes to x-3.y-3.z15.
it needs to go to x-3.y-3.z18.5
i need to get a copy of an op manual,
i will go and check it again,
Thank you for your help,
i know it is me doing something wrong,
Thanks again,
Old 01-14-2012, 10:54 PM
Smile where
hi,
where do i look for the tool pocket number on the cnc?
i think you are on something,
Old 01-15-2012, 07:12 PM
Let's start simple.
Forget fixture offsets for now.
Perform a G99 in MDI to clean any offsets. Also an H0.
Start with an empty spindle and no tool number shown on the CNC.
With a tape measure, the distance from the table to the spindle face should be the same as the Z value displayed on the screen.
Now, for a tool. Place a tool in pocket 1. Set the length in the table, using a tape measure from the back of the flange to the tool tip.
Now, T1M6 in MDI.
Again, using a tape measure, the distance from the table top to the tool tip should be the same as the Z value on the screen.
Let's hear from you what happens.
Ron
Old 01-15-2012, 10:02 PM
Thanks so much,
i will try, and let you know,
Tony,
Old 01-16-2012, 08:11 PM
Smile Thanks
hi,
Thanks that did work,
do you know how to load the tools in manual and send to
the pockets or load the pocket,
as you can tell i dont know alot about this machine,
but i want to run it.
thanks for your help...
Tony
Old 01-25-2012, 01:13 PM
Ron P's Avatar
Ron P is on a distinguished road
OK...put each tool in the pocket manually, and set up the tool table to match them. Now you have to use the CNC to precisely measure each tool. I will have to remember exactly how to walk you through that...I'm out of town right now and my info is at home...
Old 01-25-2012, 10:10 PM
slowlearner is on a distinguished road
67chevy did you get my email?
Old 02-09-2012, 07:51 AM
jwilczek is on a distinguished road
I to am interested in this procedure, the only way I have been using my machine is by setting a H postion up for each tool, rather than the tool offsets. Any more on this would be a great help.
Joe
Cincinnati Sabre 500 leggetmachine General Metal Working Machines 8 05-15-2011 11:14 PM
Help with Cincinnati Sabre 750 ctaktak CNCzone Club House 1 07-04-2010 04:31 PM
Help! with Cincinnati Sabre 750 CNC cgerchow Cincinnati CNC 0 01-13-2010 04:37 PM
Cincinnati VMC Sabre 750 HTMDGEARY G-Code Programing 8 06-23-2009 11:50 PM
cincinnati sabre parts LUNCH TIME General Metal Working Machines 0 03-07-2006 09:47 PM
