Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 12-21-2011, 09:42 AM
coop31 is on a distinguished road
procedure to replace spindle belts?
I have been having some noise in the spindle when roughing and drilling, so I decided to take it apart today to see if I could spot the problem. Turns out one of the belts is broken, and the other one doesn't look the greatest either.
So my question is, does anyone have the procedures on how to change the belts? When I purchased the machine I didn't get any books with it.
The new belts should be in my hands early tomorrow.
Thanks..
Old 12-21-2011, 09:11 PM
slowlearner is on a distinguished road
All the info is here on the forum to change the belts. I did this back in Jan. of this year to my 3 cincy's. Iirc it takes about 2 hrs to do one machine. If you have trouble there are several very experienced members that are regulars here.
Old 12-21-2011, 09:44 PM
laka is on a distinguished road
Like slowlearner said, it is fairly straightforward. Need to remove all the guards etc, loosen the motor and slide it forward to remove and install new belts and tighten her all back up. Take a paint pen and place some timing marks on the spindle and motor so you at least get the toolchange orientation in the ballpark. You will need to adjust the orientation afterwards to fine tune it so you dont have any issues with toolchanges. Don't forget to do this! Depending on your software version you can do it on the control, or you may need additional software.
Old 12-21-2011, 10:03 PM
Asankavithanage is on a distinguished road
no problems, first one you remove another two belt and adjusted motor to near the spindle, so you can insert belt one by one and after adjust the motor re point ,
ok
Old 12-21-2011, 10:21 PM
Don't I need to disassemble something on the spindle itself? I don't quite see how I will slip the belt on or off with out taking something apart.
Old 12-22-2011, 08:08 AM
Okay guys, I think Ive got it. I sent an email over to Mike at CNC Machine Services and he ever so kindly sent me the write up on what to do. I had it tore down in about 15 min and now I just have to wait for the new belts to show up.
Old 12-22-2011, 03:40 PM
mike_Kilroy is on a distinguished road
If mike at cnc services has been real helpful maybe when u get past the rush of the fix you can share his contact info here for others too?
Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit
Old 12-30-2011, 10:12 AM
Was actually a quite easy job to replace the belts. I marked the motor pulley and spindle before I tore it apart, and luckily I got it back together in the correct location so I didn't have to mess around with the spindle orientation.
I not going to put all of Mikes contact info on here, but his website is HERE if anyone wants to get in touch with him.
Spindle break-in procedure for G0704 Signal9 Benchtop Machines 0 12-10-2011 08:23 PM
OKK spindle sensor procedure PCV-55 NICK1945 OKK 0 05-07-2011 08:26 PM
OKK spindle sensor procedure PCV-55 NICK1945 Canadian Club House 0 05-07-2011 02:12 PM
Syil X3 Mill Spindle Speed Calibration Procedure Chrisjh Syil Products 1 01-12-2008 01:54 AM
Belts to replace long ball screws? What are your thoughts?? runinbymdnt Linear and Rotary Motion 11 02-17-2007 04:31 PM
