Looks like maybe TOL.EXE was deleted?
Send me your email address and I will send you a copy of mine.
Hello
I have a problem with the machine CINCINNATI AROW 1000 Year 1997
I need help or contact the service.
The problem is described below
I deleted tool mode
Please HELP ME
My e-mail adress is presform@yahoo.com. Can you please also send me instructions how and where should I put the files. Thanks a lot.
I emailed you the file.
The location of this file on my machine was:
D:\Mustang\System\SY981117\Exe\
thank you
But my machine has only C: no d: to install in the C: system.
And if you know please tell me how to carry him into the machine because the machine does not have a floppy
-Do I need to hang out somewhere or floppy has another way of entering data
Please understand my questions because in Europe is very difficult to find a service person for that machine
I'm pretty sure all of these machines came with a floppy drive. You will need some method of transfering the file and floopy drive will be the easiest for sure.
The D: drive appears once the control has booted up. It is not a secondary physical drive. I am not sure of a workaround to access the D: drive if the control is not running. Maybe someone else here will have a solution.
hello
I took out the HD and put it on the PC and put the folder which gave me the location.
But when I returned my HD machines blue screen appears
I think I have a problem now.
Please tell me something that would help me
If you took the HD from the machine and installed it as a Slave Drive in another machine running Windows XP or higher I think that would have changed the file system on the HD and it may not work at all now in your machine. But I may be mistaken.
Yes
But there is a solution
Please give my phone number if you want
To contact you
I put my hdd on win7. And already told you that now I can only see a bluescreen. Do you know about somekind of solution or can you give me conntact from someone who can help me. Thanks.
MAG - The Global Machine Tool Manufacturer: MAG provides support for these machines. You can try them.
Thank you very much for your time for solving my problem i hope that i will solve my problem.
Thank you and have a nice day.
