Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 12-01-2011, 04:15 PM
lineborn is on a distinguished road
Angry cincinnati arrow drive problams,please help
my cincinnati arrow 500 1997,acramatic 2100,bds4 drives,my issue is that when i first power on the machine everything is fine no falts or problams ,when machine power required ,i press power again ,some contacters engage but the drive dont power on and a fault 39-6 drives ready signal not seen ,servo ready control input not seen,i recently unhooked the forth axis and i did instal a loop back plug,i have been working on this issue for months ,i feel its something small i am over looking please help if you have encountered this thank you
Old 12-01-2011, 05:45 PM
mike_Kilroy is on a distinguished road
machine worked b4 removing 4rth axis?
machine has not worked since removing the 4rth axis?
both statements 100% true?
if so then u didnt jumper something.... bds4 has drive ready relay output that goes to a2100. not sure what ur loopback plug does so cant say whether it has jumper for this or not. u probably need to jumper these 2 wires that were in the 20pin white molex plug on front of bds4 so a2100 sees 4rth axis as "ready"
Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit
Old 12-01-2011, 07:15 PM
thank you for your help,on the drives i have a low voltage red light on all ,i have all the plugs unpluged on the forth drive and the dc wires unhooked,if i manually engage the magnetic contacter for the drives all the faults go out on the drives and the lights are green suggesting the drives are good ,do i need to do anything in the maintence section of the a2100 control,maybe turn something on or off ,again any help is appreciated
Old 12-02-2011, 06:23 PM
20 pin main connector on front of each axis. bottom 2 pins are fault relay output. u gotta short those 2 pins together or you will get this result.
Old 12-03-2011, 07:33 AM
thanks for the help, i have one added issue ,on the hand held pendent i just noticed that on the z axis readout it says not ready ,im assuming this is were my problem is ,any suggestions,thanks
Old 12-03-2011, 02:22 PM
so when u push the green go button it says drives not ready & pendent says Z particularly not ready.... so. when u hold in a contactor it shows green lite on the z bds4 drive??? this does not make sense...... plse confirm
Old 12-04-2011, 07:30 AM
mike,when main power is applied control off this is what i see,psr - no lights,on the vfs5-sys ok green light,cpu ok green light , on the bds4 units thair 4 units thay all have sys ok green lights ,thay all have undervolt red lights on , after i press the control green button the system loads ,the pendent says, x +.00003 f80% next line down ,y+00003 s105% ,next line down says ,z-.00003 not ready ,. after i push the green button again nothing changes still says machine power required after about 10 seconds alarm 39-6 comes up ,drives are not enabled. when i go into the electrical cabinet and manually engage the drives contacter the green light for the dc bus comes on the psr .and the red underlolt lights go out on the bds4 s ,when i release the comtacter thay come back on ,,thats about all i can tell you .one thought that seems wrong is the z axis being the only coordinet that is a negitive number ,also where it says not ready on the pendent is that in fact refuring to the z axis or just to system in general, i cant thank you enough for your help ,im a one man show and if i can figure this out it will save me alot of head acks and money ,thanks again
Old 12-04-2011, 02:17 PM
1) on the bds4 units thair 4 units thay all have sys ok green lights ,thay all have undervolt red lights on
2) z-.00003 not ready
3) when i go into the electrical cabinet and manually engage the drives contacter the green light for the dc bus comes on the psr .and the red underlolt lights go out on the bds4 s
1) there is no sys ok lite on the bds4s so clearify what you mean here.... red uv lite on, ANY other lite on? greeen? red??
2) z is the issue it seems so it shud not go green and no red lites - u need to stand at the cabinet and watch the z VERY closely and report the lites compared to x&y....
3) so NO RED lite on Z???? there are like 4 reds & 1 green on each axis drive - WHAT IS STATE OF ALL LITES ON Z WHEN U DO THIS?
Old 12-04-2011, 03:14 PM
on the bds units all the lights are the same ,the control volts light is green on all units and the undervoltage red light is on on all units,when i engage the magnetic contacter manually the undervoltage light goes ouy on all units ,when i releace the contacter the undervoltage light comes back on on all units ,all the bds4 drives do the same thing with the same lights on
Old 12-04-2011, 07:25 PM
u need to be watching the drives like a hawk while someone pushes the green go button.... what happens in that first 2 seconds before it faults? lites? enable lites all come on for 1-2 sec - even z? then a red lite blinks at u on z - u need to look and see which one?
if u dont get it and want to talk, call us we will try to walk u thru it. ask for randy (Im actually out of office tomorrow)
  #11   Ban this user!
Old 12-05-2011, 06:57 AM
mike ,when someone presses the green button and i am at the cabinet watching this is what happens ,red fault light on vfs5 comes on steady ,on the bds units x,y,z units a green ballance come on steady ,on the forth axis nothing changes ,the ballance light does not come on like the others ,that is all that happened i did it three times in a row and it did the same thing.
  #12   Ban this user!
Old 12-05-2011, 07:05 AM
time for a phone call it seems..... red lite on spindle = bad. I assume the red lite comes on for 1-2 sec then the cnc shuts it all back down right? we can talk u thru more checks if u want.....
MAXAX 100 Servo Drive and motor from Cincinnati Arrow professor EBAY ADS 0 09-10-2011 10:34 AM
MAXAX 100 Servo Drive and motor from Cincinnati Arrow professor EBAY ADS 0 09-02-2011 08:23 AM
MAXAX 200 Servo Drive from Cincinnati Arrow professor EBAY ADS 0 08-09-2011 06:58 PM
cincinnati arrow drive issues lineborn Cincinnati CNC 3 06-13-2011 05:41 PM
Cincinnati Arrow 500 Spindle Drive wiring professor CNC Machining Centers 0 11-23-2007 07:47 PM
