Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 12-01-2011, 10:47 AM
slowlearner is on a distinguished road
tool change orientation
Good morning friends,
I have a Arrow 1000 with the 2100 control. It has been down for several months now and upon repair i have a problem. Startup alignment is correct
but when making a toolchange the key rotates 90 deg. Is this a job for Motionlink ? Mallard , Mike any ideas?
Thanks guys,
Scott
Old 12-01-2011, 05:42 PM
mike_Kilroy is on a distinguished road
Hi Scott,
is the issue the P1 parameter is wrong? does it always go to the SAME spot so it is consistent, just consistently wrong? If so sounds like P1 position is wrong? did rpr include removing the spindle belt so u would have lost orient position?
if so, then yes, motionlink plus to reenter right value.... u have doc how to do this? if not let me know and I will email
Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit
Old 12-01-2011, 07:11 PM
No, Mike the problem was in the control. Nothing uptop was changed nor even a drive.Yes it is consistantly wrong. Alignment is correct on cold start.That is whats throwing me off. There are not any error codes
either. I appreciate the offer for the software and may need it if I cant find my copy. I'll let you know one way or the other. Are you staying busy?
Thanks,
Scott
Old 12-01-2011, 10:19 PM
laka is on a distinguished road
I've adjusted the spindle orientation before, in the Machine Application area under system configuration.
Old 12-02-2011, 08:31 AM
maver1ck is on a distinguished road
How to set the tool change orientation depends on what vintage machine you have.
The earlier machines using Kollmorgen BDS drives required the use of motionlink to set the P1 parameter directly in the drive for tool orientation.
The next generation (Release 3 software) had Servostar (Acramatic Servo) drives, and I believe this version also had the ability to set the ATC orientation in the control, eliminating the need to use a version of motionlink to set the orientation.
Old 12-02-2011, 04:07 PM
Maverick1, yes. and if one has issues with orient and asks, the techs at Mag will walk them thru changing from P!/motionlink, ie, vfs5 drive doing it, to, a2100 doing it. sorta involved to change but they have done so for some of our customers so from then on, the drive no longer does orient but the a2100 handles it - and u set the orient position now in the a2100, not p1......
MX45VAE active tool pot orientation montyLalor Okuma 2 08-26-2010 01:57 AM
Spindle orientation prob during tool change CRABMAN Cincinnati CNC 2 01-25-2010 12:55 PM
Tool orientation in carousel. 11toma Fadal 5 12-22-2009 02:59 PM
How to change default xyz orientation RaveBoy10 Solidworks 1 03-23-2008 07:35 PM
How to change imported part orientation RaveBoy10 GibbsCAM 1 03-17-2008 08:55 AM
