Results 1 to 2 of 2
Thread: Turning - G92 Problem
    Aug 2010
    Argentina
    Hello for everybody,
    I'm really new working on CNC turning, and I'm having problems with axis references.
    I'm working in a Old Milacron Cinturn 1212 with Acramatic 850 Control.
    I've read the manual and I've set up Zero program with G92 command in MDI Screen. It has moved the axis references (As we expect) and, working on MDI line by line, it's doing really well.
    My problem is when we write a program, it moves the Zero again to Zero machine, and it causes a lot of issues, as you can see.
    If I already moved Zero to Zero Program, Why do it reset it? Should I "call" Zero into the program?
    if yes, How Can I call it? I've worked on a Milling machine before, and Zero stayed where we put, it never returned to Zero machine.
    I'll really apreciate if somebody could help me, I really need it.
    Sorry for my English, I'm writtting from Argentina.
    Regards
    Registered MetalZilla's Avatar
    Jan 2007
    Try here for an explanation: G92 Example
    www.WebMachinist.Net
    The Ultimate Online Source for Machinist Related Stuff!
  1. Problem- Mazatrol T32 -turning problem
    By Bert10 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-20-2009, 02:31 PM
  2. Problem- problem with how to observe the turning well?
    By yang_cnc in forum Mini Lathe
    Last Post: 08-16-2009, 12:32 AM
  3. problem about my first turning
    Last Post: 08-14-2009, 04:24 PM
  4. M08 Coolant Turning On Problem
    By OKK MVC500user in forum Haas Lathes
    Last Post: 01-13-2008, 06:29 AM
  5. Somebody please help me with this turning problem :)
    By gravitar in forum CNCzone Club House
    Last Post: 11-21-2006, 09:56 AM
