Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 08-10-2011, 11:30 AM
dbren is on a distinguished road
Still looking for new feedback cable
Hello,
Awhile back, my x axis feedback cable malfunctioned. I spliced in some non-hi-flex cable from a local electronics supply and just hung it over the back of the enclosure and down to the x motor. I put it inside some poly tubing to protect it and it flexes very little that way, so it will last indefinitely; however, I know I need to find the right stuff soon and install it properly.
I have tried with Lapp and other searches. Lapp makes all the paired hi-flex, but they don't make anything with individually shielded pairs. I'm looking for 4 pair 22 ga. with overall shielding and at least one pair individually shielded. Lapp says minimum 5000 ft. custom run to get 16 ft. Has anyone here seen another supply without paying $960 to Cinncinnati for the 16 ft. of cable? Mike Kilroy, I believe you checked your stock a couple months ago with no luck.
Old 08-10-2011, 12:26 PM
Al_The_Man's Avatar
The only cable I will use for encoders is Belden 9891, it is individually shielded pairs and over all braid shield, it also has a larger pair for the power.
The only problem is finding someone to sell you a short length as it is mucho $$$.
Old 08-10-2011, 04:57 PM
Thanks Al,
My bend radius is 2" and Belden specs this one at 3.5". I also need hi-flex which is normally rated at about 1 million bend cycles. I sure wish that Cinncinnati had designed with a larger bend radius or a hanging loop which would eliminate most of the bending.
Old 08-10-2011, 06:42 PM
mike_Kilroy is on a distinguished road
dbren, I cant imagine us not having a 16' of hi flex encoder cable for these motors.... if u email me the motor part no (again maybe?) I will go pull some tomorrow and email you back an offer. prob what our guys said we did not have is complete cable with proper connectors on both ends? mike@KilroyWasHere.com
AC power cable in the same cable carrier with motor cables bandtank General Electronics Discussion 12 06-01-2010 06:06 PM
Cable carrier competition: The way you use your cable carriers could earn you a cash igus Product Announcements & Manufacturer News 0 01-22-2010 12:06 PM
Looking for Feedback 5stargn PCB milling 5 12-22-2009 12:56 PM
Need Help with acquiring new servo feedback cable fabshop General Metal Working Machines 3 09-25-2009 07:39 PM
Feedback veteq Benchtop Machines 1 12-29-2008 10:29 AM
