Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 08-09-2011, 07:34 PM
pquerro is on a distinguished road
A2100 Table Jerking/Servo Oscillation
I have a Sabre 1500 with an A2100 control. BDS4 Servo Drives. I can move the Y and Z axes just fine. The X axis however jerks, I'm guessing a servo oscillation. The control then errors out with a Foldback error. I can move it very slowly for a bit with the MPG but any speed at all and it begins jerking. Anyone have any ideas - Drive? Motor? Feedback? Thanks
Old 08-09-2011, 09:09 PM
maver1ck is on a distinguished road
Although you didn't mention it, I'm assuming you have scale feedback on the x-axis. If so, the first thing I would do is check is x-axis bearings and ballscrew for looseness. I recently worked on a similar problem on a 1250, and it turned out to be the x-axis thrust bearings were installed incorrectly.
Old 08-09-2011, 09:38 PM
Yes, It has scale feedback. Also, I didn't mention the fact that it was running fine until this occurence. It was mid cycle and all of a sudden started jerking and errored out. I will definetely check the bearings and screw. Can I swap the x and y drives to eliminate that from the equation?
Old 08-10-2011, 05:45 AM
On the smaller machines, the X and Y drives are identical and can be swapped, but you should perform the drive setup procedure if you plan to leave them swapped for any actual production.
On the larger models, they started using different amp drives for the axes. From my experience, you can swap any of the drives short term as a test, but if they are different amp drives, obviously you'll want to put them back as soon as the test is over.
Old 08-10-2011, 07:13 PM
mike_Kilroy is on a distinguished road
drive? motor? feedback?
maver1ck gave u some good checks. if drives & motors r the same on x&y then swappking drive will check that part. ditto swap motors if same. did u ck the feedback? mounting head screws come loose?
did u try at different table location? sometimes a cable or scale problem will only happen at one spot on table so try other spots to verify not location dependent.
usually last thing we do b4 a failure is cause. u were machining.... so sounds like something BROKE rather than is slowly wearing out. what can break? cable? scale looseness? I had a scale glass come unglued inside one time and it moved back and forth 1/2 in and caused this result....
u can learn a lot from ur 2100 screen: commanded position & actual position..... can u push table by hand? does actual pos display move as expected or is it 'dead' for a bit then move like the backlash maver1ck was trying to help find?
handcrank .001 and what does actual pos display show? no movement? or if u go 5 + then try minus .001 does it show unusually large backlash? ur description sounds like hmmmmm guess.... .010" backlash problem.
btw, when our bds4 drives (or any) go into foldback, that is an effect not a cause; drive is just telling u that jerking back and forth in that oscillation is pulling too much current so drive folds it back to protect stuff; result is the 2100 sees excess position error and faults out.
so sounds like something broke, bang, all of a sudden. it usually results in excess backlash between the scale and motor shaft and the result is what u describe. call us tomorrow if u poke around more and want to ask questions; we try to keep these motors and drives in stock for quick turn around/exchange while/if we repair the broke ones. bet u find mechanical issue creating the backlash tho.
Old 08-10-2011, 08:36 PM
Thanks for the info. I dove under the way covers. Is the scale difficult to remove? Any tips?
Old 08-11-2011, 07:27 AM
I cant help; don't recall whats under the hood - we normally just work on the motors, spindles, and drives off the machine or thru internet connection to them on the machine.
Old 08-11-2011, 08:52 AM
Mike, you mentioned to call. Can you PM me your phone #
Old 08-11-2011, 03:30 PM
i tried all morning before I left the office but ur mailbox was full. i tried again just now and it went. sorry for delay. i will be in office tom morning again.
Old 08-12-2011, 02:08 PM
Mike,
I will call Monday.
I powered it up again to check a few of the things you listed and with the way cover back there is a noticable "hiss" coming from the motor. Almost sounds like an air leak does.
The actual position display updates when I push on the table before I power on the servos. After the servos are powered on it does not change when I push on the table. No noticable backlash either.
The commanded position vs. actual position seems to be operating properly when using the mpg.
I jogged it a few rotations of the moter very slowly using the mpg and the "hiss" changes volume and tone as the motor changes position.
  #11   Ban this user!
Old 08-12-2011, 02:33 PM
back to basics again; what is the problem?
is it when you move it moves the right way and the right amount but not smoothly (jerky) then stops where it is supposed to stop and sits still?
or by oscillation do you mean you tell it to move and then it begins to oscillate back and forth and does not stop until you turn off power?
these are not the same thing.
perhaps a better description would help point the right direction?
Old 08-12-2011, 03:01 PM
Al_The_Man's Avatar
As Maver1ck suggested, I would see if the drives are the same size and swap them if so, just to see the difference.
If the problem follows the axis, I would be tempted to remove the motor mechanically, leave it connected and see if you still have the problem.
Sabre 1500 A2100 Servo Enable Signal pquerro Cincinnati CNC 7 02-27-2011 07:26 PM
Cincinatti A2100 Arrow500 servo failure darthzader Cincinnati CNC 0 10-06-2010 10:01 PM
Oscillation Ashish B Linear and Rotary Motion 0 04-06-2010 10:18 PM
servo oscillation nebyeh Servo Motors and Drives 22 02-25-2007 05:14 AM
Oscillation During Axis Acceleration Geof Haas Mills 4 07-18-2006 04:29 PM
