| Cincinnati CNC Discuss Cincinnati CNC machines here. |
Hi. I work with sabre 2000 cincinatti milacron with acramatic 2100 controller. Last 3 weeks every other hour alarm comes up on the screen NCA spindle lube alarm. I have to go at the back and reset it everytime. Red light-"low air" lights up and after i reset it all back to normal for another hour or so. Spindle oil tank is properly filled btw so there is no prob with that. Might it be weak air compressor? But it was working for number of years in same workshop and was alright. Any suggestions. Tnx in advance |
| There is a digital display on the oiler unit that displays the current pressure going to the machine. It's been a while since I've use an Arrow but from what I remember the pressure can only fluctuate a very small amount from baseline or you will get a low/high pressure alarm. I think the number on the display should be 6 (bar?) but not totally sure. Adjust your air pressure and you should solve the problem. |
| Need Help!- 2002 Haas SL-10 low lube alarm | gangpw924 | Haas Lathes | 10 | Yesterday 10:27 AM |
| Need Help!- re Spindle Lube and Lube Pump | robkuhi | Tree | 15 | 10-24-2011 12:49 PM |
| Need Help!- 2002 Haas SL-10 low lube alarm | gangpw924 | Haas Mills | 2 | 02-11-2011 02:38 PM |
| Need Help!- LOW LUBE PRESSURE alarm | CORBIN92087 | Haas Mills | 6 | 08-11-2010 09:47 AM |
| Fanuc O-md Lube Time Alarm!!!! | sco999 | Fanuc | 5 | 04-28-2007 10:14 PM |
