Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 07-22-2011, 02:14 PM
davekensco is on a distinguished road
A2100 Control Realtime Board Spares
I have three Cincinnati Arrow Vertical Mills with the A2100 Control. I would like to purchase a spare Realtime Board #3-424-2168A02 for spare in case
of failure. My Question is, can I just replace the board or is there steps involved to make it compatable with each machine, such as serial control number. I so, is it a matter of cahnging the BIOS or is the info burned an EPROM? Would this be the case for Bridge Board (BBB) also?
Thanks,
Dave
Old 07-23-2011, 09:35 AM
Ron P. is on a distinguished road
IIRC You can just replace the board, there's nothing specific about it to the CNC. There are CMOS settings that must be made in case of battery failure. Don't recall what they are.
Bridge Board can also be replaced at will, no settings are on it. It plugs into a key at the back of the card cage, and that key contains the CNC serial number. The option code for that CNC will look at the serial number key for a match so that config and options are enabled.
HTH
Ron
Old 07-23-2011, 09:49 AM
Thanks Ron,
Dave
Tags
a2100, bbb, realtime
A2100 Bridge Board Repair cncatj Cincinnati CNC 3 05-20-2011 07:47 PM
Help on Realtime board replacement sunnybank Cincinnati CNC 2 10-13-2009 02:10 AM
Problem- a2100 rt board failure (again) edsgarage Controller & Computer Solutions 1 09-07-2008 05:18 AM
Need Help!- Seig x2 Speed Control and c6 Control Board skmetal7 Benchtop Machines 2 04-21-2008 03:17 PM
A2100 control touch screen problems! a_davies616@hot General Metal Working Machines 1 04-19-2007 12:44 PM
