Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 06-07-2011, 09:02 PM
Clawsie Machine is on a distinguished road
Smoked POWER SUPPLY
Guys, finally back on-line after a while as I couldn't get logged in. BUT I smoked the main LARGE BLACK power supply in my machine today. It's the large black box to the left of the spindle drive and axis drives.
Anyone know what the cost of these are or where i can get one soon?
Thanks, John
Old 06-07-2011, 09:26 PM
slowlearner is on a distinguished road
Mike Kilroy is a member here and he is the man to talk to.
Tell him Scott sent you.
Old 06-08-2011, 07:49 AM
MCPservice is on a distinguished road
Smoked power supply
Do you have any information on the power supply.
Old 06-08-2011, 08:02 AM
At this time, I KNOW NOTHING about it. I know it's that as the repair guy came in and switched it out with another one (also not working right) and it solved my problems.
I have a '97 Arrow 500. The problem was if you tried to turn the spindle on ABOVE 200 RPM, it would fault out. BUT I could get it to ramp up in 100 RPM incriminates to operating speed of 1700-1900 RPM, but no real load on it then as just walking around the O.D and I.D. of the parts.
BUT yesterday it started to smell, like it was either really hot or burning, so I shut it down. I was facing with a 2" cutter .030" deep.
The problem with the one the repair guy had was it wouldn't shut off the spindle and fault out. But we could "cold start" right to 6000 RPM.
Any help would be great.
Thanks, John
P.S. who is Mike Kilroy and who can I contact him???
Old 06-08-2011, 01:47 PM
Ok, this what I found off my smoked Power Supply:
Input: 230 VAC, 50 Amp/phase, 3 phase
Output: 310 VDC, 50 ADC
Model No. PSR 4/5-250-7500
If that helps????
Old 06-08-2011, 09:22 PM
maver1ck is on a distinguished road
Since you asked, Mike Kilroy has been repairing the Kollmorgan drives for a number of years. Once you contact them, they'll have you send your drive to them, they'll inspect it and give you a quote to repair it. If you need to reach them contact information is:
Mike Kilroy Corporation
10 W Trotwood Blvd
Trotwood, OH 45426
Phones: (937) 660-5313
Kilroy was here
If you need to get the machine running immediately, you should also try Siemens ESD (800-354-0426). They used to keep these in stock for exchange. Not sure if they still offer this, but it would get you running within 24 hours with a repaired drive, then you return yours to them to be repaired for the next customer in need. If they don't offer an exchange anymore, for most items they offer a flat rate repair of the components so you know what it will cost before you send it to them.
I have also worked with less expensive sources that can repair these drives and power supplies, but turnaround times can be 2-4 weeks.
Old 06-09-2011, 07:45 AM
Thanks, need to keep that in mind. I also found a guy a lot closer to me at Magna Products Corp.
Magna Products Corp. the Servo Specialist | Rochester, NY
Spoke with a very knowledgeable guy on the phone and got a nice quote 10 mins. later.
Does anyone have any feed back on this company or there products?
Old 06-09-2011, 06:29 PM
mike_Kilroy is on a distinguished road
Let us know if you still need help later.
If u opt to not use someone else, we can likely repair this in 1-2 days for you if u need it that quickly. 937 660-5313. thanks
Old 06-10-2011, 06:55 AM
Thanks, Mike. I found this company, Magna, in Rochester NY. Now even though there is the boarder there, it's still close to me, and I was quite impressed with there guy Scott on the phone. Prompt and very nice service. Price seems very good and at the time, I was sorta scrambling. SO I sorta gave them the verbal OK that I would order from there as long as the local service guy was OK with it and I didn't find out any bad things about there work or services.
BUT it is nice to know there are others out there that CAN and WILL supply help and knowledge for when the time come that repairs are needed. I have saved Mike's company in my "bookmarks" for future references.
Thanks, John
Old 06-10-2011, 07:38 AM
Thanks for reply. We have probably a 100+ of the various older drives and some of the motors from those machines here (since we supplied them originally to CMI).
Let us know if we can help in the future.
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
controller power supply 115/230v OK for Australian power? Momill Australia, New Zealand Club house 8 07-07-2011 11:06 AM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
AAAGH! My CNC coilwinder smoked!! Swede General Electronics Discussion 5 01-09-2004 09:47 AM
