Results 1 to 4 of 4
Thread: Help with spindal fault message
    Aug 2010
    canada
    When it turn on the spindal it will either do 2ish low rpm rotations the stop, or not come on at all. Then will come up with thisone alarm.
    Cause:
    the spindle enable signal has been set on by the a2100 control but is not recieving the spindle ready signal from the kollmorgen spindle drive.
    remedy:
    check the active led on the spindal drive see if it is aluminated
    make sure fault led is not on
    check condition of axes drive overloads.
    If any can give some info please........
    Sep 2010
    did u check the 3 things it said in remedy? what is answer to each?
    red lite on vfs5 is fault and bad. on?
    you say turn on then it goes 2 or so revs slow and stops? this is not a "normal" failure mode.... tell more about what is happening here?
    Aug 2010
    canada
    yes the right light is on. And just like I said if you press cylce start to run a program the fault message in my previous post comes up.
    Now I was running it fairly hard with lots of chatter and vibration the spindal slowed down and broke the endmill during the cut.
    How can I get that red light off?
    Sep 2010
    not enough to go on.
    best guess: you have an output IGBT or driver shorted and so if you push go button at the right time it is putting out ok for a very small portion of a second - long enough to get current into the motor and give it a kick so it sometimes moves a small amount and stops.
    Only test that seems valid to determine where the problem is: remove Ma,Mb,Mc motor leads from drive. power up again and see if fault lite comes on: if drive is probably shorted. If not, motor or cable has short.
    If fault still, then it still might be the feedback resolver bad too. not sure you could check that - too complex.
    Id recommend if fault still on w/o motor you send it in somewhere for repair. PM me if you want us to help.
  1. Need Help!- can you lock the spindal in MDI
    By firekoe in forum Fanuc
    Last Post: 02-02-2010, 05:04 PM
  2. Help....spindle overload fault message
    By icedog in forum Dynapath
    Last Post: 10-12-2009, 11:45 AM
  3. Problem- Tree 330 Dynapath 10 Fault or Message
    By machinist360 in forum Controller & Computer Solutions
    Last Post: 02-28-2008, 09:05 PM
  4. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport and Hardinge Mills
    Last Post: 10-08-2007, 04:35 PM
  5. Axis drive fault/off error message
    By Healey in forum Bridgeport and Hardinge Mills
    Last Post: 11-08-2006, 04:49 PM
