| Cincinnati CNC Discuss Cincinnati CNC machines here. |
I found a floppy disk with a few interesting files on it - from my past life with Cincinnati Milacron Electronic Systems Division / Vickers / Siemens. I was involved with A850SX and A2100 mainly. I recall writing a subroutine like this for 850/950 and I'm pretty sure I modified it for A2100...anyhow, reproduced here for your benefit. Use with care...I can't remember exactly what moves it made! Ron (PGM, NAME="external thread sub example", TYPE="A2100_274", EXEMODE="STANDARD", PATH="PATHALL", ACCESS="OPEN", CREATED="THU MAR 16 2000 12:46:22", MODIFIED="THU MAR 16 2000 13:37:06", LEVEL="1") :G0 G70 T5 M6 N010 X7.0 Y5.0 Z-10.0 F200. S2000 M3 N020; Use parameters in the CLS block to pass information to the subroutine: X, Y=center of boss in X and Y, Z=surface of part, K=thread lead, D=depth of thread from surface, O=major diameter, F=feedrate at tool tip N030; starting condition requirements: Correct tool in spindle at proper RPM, coolant specified as desired, all parameters specified in above line established N040; Tool data for nominal diameter and diameter offset must be correct! N050; Subroutine makes one pass only! N060 (CLS, "helical sub" X7.0 y5 Z-11 D1 K0.06 O1.9875 F100) N070 M2 ; ; N100 (DFS, "helical sub");this sub threads from bottom to top! N120 (MSG,Position over center of boss, 0.100" above part surface) N120 G90 X[&X] Y[&Y] Z[&Z]+0.100 N130 (MSG,Move X and Y clear to upper RH of boss) N130 G00 X[&X]+([&O]+[$tool_data(0)nom_dia]+[$tool_data(0)dia_offset])/2 Y[&Y]+([&O]+[$tool_data(0)nom_dia]+[$tool_data(0)dia_offset])/2; N140 (MSG,Drop Z to bottom of thread) N140 G0 Z[&Z]-abs([&D]); N150 (MSG,Feedrate move X to 12:00 position) N150 g1 X[&X] F!; N160 [#numthreads]=abs([&d]/[&K]);calculate number of helical arcs N170 [#degrees]=([#numthreads]-int([#numthreads]))*360+90;calculate degrees in last partial arc N180 (MSG,CCW helical milling ;int([#numthreads]):3.0; full circles plus ;([#numthreads]-int([#numthreads]))*360:6.3; degrees) N190 F([&O]+[$tool_data(0)nom_dia]+[$tool_data(0)dia_offset])*[&F]/[&O];set feedrate taking cutter diameter into consideration N200 g3 X[&X] Y[&Y] Z[$curpos_pgm(Z)]+[#numthreads]*[&K] E[#degrees] L([&O]+[$tool_data(0)nom_dia]+[$tool_data(0)dia_offset])/2 I[&X] J[&Y] K[&K] N210 (MSG,Retract Z to work surface = 0.100") N210 G0 Z[&Z]+.10 F[&F];retract Z to top of part + 0.1 clearance N220 (MSG, Move X and Y to center) N220 X[&X] Y[&Y];not required, just for the hell of it N230 (MSG,) N230 (ENS) |
| Just so it's clear, this subroutine allows you to make an external thread mill with one subroutine call. The sub handles all math and positioning. Before making the subroutine call, make sure that the following items are as described: - Correct tool in spindle, with tool data for nominal diameter and diameter offset correctly set in the tool table - Tool running at proper RPM and direction - Coolant on or off as desired In the CLS block, enter the following: X, Y=center of boss in X and Y Z=surface of part K=thread lead D=depth of thread from surface O=major diameter F=feedrate at tool tip That's all you have to do - the sub handles all math, blend in and out, coordination of Z and K so endpoint is correct, etc. It's also all written in G90. I hope this helps someone. |
| I found this thread interesting... | Jeff-Birt | Taig Mills & Lathes | 1 | 11-28-2009 02:54 PM |
| archives | bobcable | Forum Questions or Problems | 2 | 11-18-2009 11:19 PM |
| Thread milling with A2100 | Clawsie Machine | Cincinnati CNC | 3 | 10-19-2009 12:17 PM |
| Cininnati A2100 Mill wont turn on! | surreyeng | Cincinnati CNC | 2 | 09-21-2009 10:42 AM |
| found a cheap Acme thread source | nicanor76 | DIY-CNC Router Table Machines | 6 | 06-14-2008 12:12 PM |
