Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 05-05-2011, 06:29 PM
KLUCAS4 is on a distinguished road
Sabre 500 Acting Crazy
The machine has been really hard to start like 3 or 4 hrs of trying to get past the TGN Led on the servo amp before it will start. I know the TGN is supposed to be from the z axis feedback cable but after swapping endcoders and buying a new cable the TGN still persist. The alarm stays on the same Axis.
Then today when I came in I started seeing spindle drive fault errors and the spindle would not run at the programmed speed it would be slow the right then slow again.
I powered the machine down and now Its stuck on host control ini screen and the led's on my damp board are as follows . RUN Is Red , SERV Is Red, apwr is green and dpwr is green.
Any help would be greatly appreciated.
Mastercam X4 to Mach3 - machine acting crazy. CarlofET DIY-CNC Router Table Machines 2 05-24-2010 07:43 PM
Need Help!- Fanuc OM acting up Machinist3 Fanuc 12 02-23-2010 07:34 PM
Need Help!- Fanuc 18i acting crazy luke1626 Fanuc 8 10-02-2009 06:49 AM
THC acting up Alex S.A CNC Plasma and Waterjet Machines 1 09-24-2007 08:31 AM
Maxnc acting up! abomb55076 Servo Motors and Drives 0 07-31-2006 05:04 PM
