03-28-2011, 08:10 PM
A2100 BIOS boot preventive maintenance | | AccuMillGuy's recent post got me paranoid about my batteries dying - I have no idea how old they are. So I have two questions:
1) How do you replace the batteries w/o risking losing the factory BIOS on the RT and WS board? Speed? Luck? or both?
2) Is there a working procedure to backup the bios on each board in case it goes bad?
After some unwize activities, I can assert that speed alone isn't sufficient. I measured the voltage on the WS board battery and it was hovering around 2.95V versus a new battery voltage of 3.25 so I decided to replace it (figured there would be a cap to give me a few seconds to swap batteries - WRONG). I carved a tool from a popsicle stick to pop the old battery off w/o chance of shorting the supply then, after a few practice runs, I popped it off and snapped in the new battery. Wasn't off more than one second. However, when I booted the machine, the time was reset and I got a "memory configuration changed" error and OS loader failed to start. I had taken pictures of all the setup screens before this and was able to get the machine running by restoring the values, but I learned that speed isn't the answer. Luckily, my RT board is in better shape (3.07V) so I have time. Since apparently you are hosed if this one gets cleared I am thinking I'll have to use some alligator clips and a spare battery to work out a make-before-break procedure. Sure wish there was a way to save a backup...
