Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 03-19-2011, 06:20 PM
logger is on a distinguished road
Help Align me
Just got my new cinci 1000 under power. How do I align?
Old 03-19-2011, 08:24 PM
TickTock_ is on a distinguished road
Press and hold the align button on the pendant. X,Y,&Z will slowly move to the limit switch.
Old 03-19-2011, 08:32 PM
This does not seem to work. Do i have to press F1 or F2? Can the door be open or closed? Any other ideas?
Old 03-19-2011, 09:28 PM
Yes, press and hold F1 after you press the Align button. Door can be open or closed for this. Is your pendant powering on properly? You should see F1 labeled "Axis Align" and F2 labeled "Mech Align" in the LCD.
Old 03-19-2011, 09:57 PM
The pendant does have power to it I can move all the axis. The fine ajust wheel on the pendant (cant remember what it is called) works but I can't change the speed. ex. .0001 change it to .01.
Is it possible that the f1 and f2 buttons are nfg? How can I check?
Old 03-20-2011, 01:40 AM
ZigwareCNC is on a distinguished road
Do align first. As TickTock said...
1) hit align button on pendant.
2) Now pendant display should show (F1 axis align) and (F2 mechanism align).
3) Assuming #2 shows correct, hold F1 and the machine will auto-align all axis.
4) Once done, Hit F2, verify the tool drum is positioned at #1 (main control display asks this question on the bottom of the screen), then it F2 again to confirm.
Now should be aligned.
Old 03-20-2011, 09:37 AM
And if nothing hapens when I press f1 or f2? Are the buttons on the pendent broken.
Old 03-20-2011, 10:12 AM
It does sound like F1 is non-functioning if you cannot select .0001 speed while in the Jog or handwheel mode (did you try both?). Early during poweron (well before the Quick Start option is displayed), all LEDs in the pendant flash on for an instant. See if the one under the F1 also illuminates. If not, that corroborates the F1 malfunction. If all LEDs flash it is inconclusive since the LED may still work even if the button contact is worn. I am not aware of any way around the pendant buttons. I tried F1, alt-F1, etc on my machine but it appears there are no keyboard alternatives. If you are handy with a DMM and a soldering iron, you could open the pendant and debug/repair. If you are lucky, it's could be just a cold solder joint or broken wire you can find by inspection.
Old 03-20-2011, 01:02 PM
If you see the messages on the pendent but the F1 does not do the axis align, does F2 do the tool changer align? If both buttons are not working, then there may be a bigger problem.
Old 03-20-2011, 09:36 PM
Ya both buttons are not working. I can not change incr. for the hand wheel or can not calibrate (align machine) Is this a common problem for the pendent on this machine?
  #11   Ban this user!
Old 03-20-2011, 11:51 PM
I wouldn't say its a common problem (actually never heard of the Function buttons not working). I have not had any pendant issues personally other than a potentiometer issue on the spindle override.
  #12   Ban this user!
Old 03-21-2011, 07:47 AM
Anybody know where to get a pendent repaired?
3d Align coykiesaol General CAD Discussion 0 11-30-2010 01:15 AM
Align mirrors ? etienne delcuve Laser Engraving & Cutting Machines 4 09-17-2009 03:44 PM
PCI align solid robyc01 EdgeCam 1 07-27-2009 09:27 AM
align left kendo EdgeCam 2 11-19-2008 05:22 PM
Align Honing or Align Boring ? jonbanquer General Metalwork Discussion 10 11-09-2008 09:33 AM
