Dear friends,
i am having Cincannati A850 vmc. But i am not having programming manual for it. i tried to make drilling cycle.
G83 X50.0 Y50.0 Z-20 R2.0 K2.0 F5
i am not using ATC. so i am loading the tool by manual.
if i select load status to manual ,every M02 it is asking me to unload the spindle tool. if i select load status to none , alert 15214 Tool Absent or data error is comming.
so if it is possible to run the drilling cycle with out tool date? and what is the M code for Program end and Rewind? in fanuc it is M30. but when i call M30 in A850 alert no program found is comming.
so in operations manual for A850
M30---End of segment and M32-- End of last segment, what is the different between this,
so kindly help me,
Thanks and Regards,
Keyan
