Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 02-19-2011, 04:54 PM
Heinster is on a distinguished road
Problem - Pendant Link Failure
We posted a few weeks ago regarding some general problems with the Arrow 1000 having some random and untraceable issues with stability. We cleaned all the boards in the PC and the system is now very stable. However, we are still encountering a primary pendant link failure every so often, usually when the pendant is being handled.
Any thoughts as to what the issue could be?
Thanks.
Old 02-19-2011, 06:33 PM
mallardfizz is on a distinguished road
primary link fail
hello my experiences would suggest that you have a connection problem with the pendant. i would suggest seperating the pendant face plate from the black body of the pendant ( remove the six screws and pull it apart ) and checking the internal connections. it is possible that you have a damaged case and that the damage is allowing the pendant to flex and causing the primary pendant link fail. if there is no damage and no loose internal connections then you are left with no other option than to change the pendant
regards
mallardfizz
Old 03-01-2011, 12:25 PM
John_B is on a distinguished road
Ditto on mallardfizz's recommendation! I've had this same problem for 2 years or more now, and have gotten that same diagnosis from many sources. As of yet it hasn't stopped me, it just takes a while to get the machine started (when I do shut it off, which isn't very often...).
The rebuilt pendant is over $2500 as I recall, so we're holding out until we have no choice (not my decision).
Rgds,
John B
Old 03-13-2011, 10:05 PM
slowlearner is on a distinguished road
I just started having this problem last night and think it may be in the cable between the pendant and the monitor.
Old 03-18-2011, 12:34 AM
ThePainter is on a distinguished road
Heinster
You might try updating the diagnostic s/w in the control before ordering any parts. Contact the tech support group at Siemens - they can e-mail it to you. Hot Line#800 879 8079
RS232 link problem on CL200 with M64 Controller rkucbel1 Mori lathes 5 02-03-2011 08:12 PM
cincinnati milacron pendant link failure cncrussell CNCzone Club House 0 09-30-2010 09:57 AM
MDI / RAP failure s&swelding Cincinnati CNC 10 04-30-2010 01:24 PM
Need Help!- Fanuc 0i-TC accurancy problem after power failure sotos37 Fanuc 0 01-27-2009 12:18 PM
cad link problem helix77 EdgeCam 0 07-10-2008 01:38 PM
