| Cincinnati CNC Discuss Cincinnati CNC machines here. |
I got a small job turning some weld-in weights for clutch pressure plates and have been having issues getting the machine to play nice. I'm finally to the point of testing my program, but now I have found one more issue. After the cutting operations (turning and parting), I stop the spindle and coolant with an M5, change to the bar puller, feed it on, M80 to open the chuck, then... ...nothing. It won't retract the turret along the Z axis to pull more material out. It says initialize chuck jaws. Is that not the right method? I was going to retract, M81 to close the jaws, then retract more to pull off the bar. Any help you could give me would be appreciated, these parts are already overdue. I've been feeding them one by one to get through the job, but this is getting rediculous. |
| I'm at home, so the code will have to wait until tomorrow. I'm in FPM. As soon as it executes the G80 and opens the jaws, it should execute a G1Z1.$ at F10, but it gives me an alert saying initialize chuck jaws and freezes. |
#10
| Since I only had to do 200 parts, I pulled it by hand. My replacement puller collet has not shown up yet, so I ran the parts without it. Now that the deadline is gone, Monday I'll try the dwell and see if it makes the difference. |
#11
| Here is the whole program. How would I edit this to add dwell time using the 850's G04 Dwell command? % :G90G70G63G0X4.Z4. T1M26 G92S3500F3 G97S300M42M4 M8 G0X.325Z1. G1X0F3 G0X.325 Z.83 G1X.105 G0X.325 Z.537 G1X0 G0X4.Z6.M5 G0X0Z.6 G1F20Z.25 M80 Z.720 M81 G0Z4. M2 |
#12
| I have an Acramatic 900 manual at work, I'll bring it home tonite. I'm prety sure most of the 900 & 850 codes were the same. G04 sounds right & you'll need the code for how long to dwell. It might be G04 S4 for a 4 second dwell. |
| Can a 1986 Mazatrol cam M2 controlls run DNC | tball | CNCzone Club House | 2 | 05-15-2012 02:57 AM |
| Matsuura 1986 MV-500 CRT went Black??? | Tony(BDE) | General CNC (Mill and Lathe) Control Software (NC) | 2 | 07-23-2009 08:44 PM |
| Need Help!- I need a speed change plate for a 1986 YCM-40 supermax | orizaba | Want To Buy...Need help! | 0 | 12-27-2008 09:21 AM |
| cinturn lathe with an acramatic lathe | PETE1968 | Mastercam | 18 | 10-15-2008 08:37 PM |
| cincinnati cinturn 8 | magicmachine | General CNC (Mill and Lathe) Control Software (NC) | 0 | 10-05-2007 05:23 PM |
