Results 1 to 4 of 4
Thread: Preload 8000 RPM spindle Arrow 500
    Feb 2006
    Spain
    Hello everybody, unfortunately I have to replace main spindle bearings on this machine (built in 1998 ), afther to adjust the preload start spindle run out at 500 rpm and in five minutes some click noise appears and afther several checks I understand that the top bearing have been damaged. Of course I follow the drawings included on the machine to asembly but it seems that I do something wrong
    Does somebody have any instructions over how to aply the preload, in this case I adjust checking fo spindle movement in axial direction 0,005 or less
    Well thanks to all
    Hope good news.
    Ninus
    Aug 2008
    The preload on the grease lubed bearings in my 6000 RPM Arrow 500 spindle is set by the inner and outer spacers and should not require adjustment provided the bearings are oriented correctly. Is it possible you damaged the bearing driving it into the bearing bore?
    Joe
    Nov 2010
    Wink
    There are so many factors that go into rebuilding a spindle properly. The most common cause of failure is too much grease. Most of the one's I have done take no more than 2.5cc's. Speaking of grease,did you use Kluber NBU15? If not,that was your biggest mistake. As for pre-load,I use an indicator and adjust to ~.0005" play when cold on the bench.
    Also everything MUST be CLEAN!!!(Including your hands).
    Dan
    Feb 2006
    Spain
    You are rigth
    Thanks to both for your answers, especially to Dan, you are rigth, my hands have to be clean, I think there was be the problem.
    Tomorrow I have to go to replace again, I'll tel you something.
    Thanks to both again
    Ninus
  1. arrow 500 spindle motor fan
    By Slick27 in forum Cincinnati CNC
    Last Post: 01-26-2011, 03:45 PM
  2. preload on spindle bearing
    By adryan in forum General Metal Working Machines
    Last Post: 06-21-2010, 06:59 PM
  3. Replies: 4
    Last Post: 10-05-2009, 10:29 PM
  4. Arrow 500 spindle module
    By JWC in forum Cincinnati CNC
    Last Post: 09-16-2009, 11:21 AM
  5. Need Help!- Spindle bearing preload
    By chevyguylt1 in forum Fadal
    Last Post: 05-04-2009, 10:53 AM
