I have a record of parameters for my arrow 500 control diagram 91202599 model ere serial # 7042 c00 95 0385. For the x y z and spindle . But are all parameters the same for every machine?
hey all,
i'm wondering if anyone has parameters for this machine with the CT control. Or if anyone knows where i could get them it would be great a huge help.
thanks a bunch!
-zack
Did you loosed power to the memory module?
Purchased the machine running and I am unaware if the battery ever died. I replaced the battery with power on after installing machine at my shop. There are values in the drive parameter settings which I assumed would have been lost with a power loss. Only thing that I do notice is that the backlash comp values are not there. The only software problem that I have at this time is a static ram corrupt error on the boot, which after clearing 4-5 times it does not reoccur while the machine is running. Had a few other problems with the machine in regards to uneven power supply due to a phase converter, but I believe I have those problems resolved.
Does anyone know what the static ram corrupt error actually has an effect on. I am being told that it is simply a need to reinstall the software because it is a corrupt file, but am hesitant at this point and time seeing as the machine runs without any issues. Note: machine time since I have purchased it is very few hours, i.e., barely no parts being run at this time yet, just simple machine functionality testing. Mark Reuss 413-329-1503.
