Results 1 to 3 of 3
Thread: Arrow 500 Z axis excessive following error
    Apr 2010
    Would anyone know the cause of a z axis excessive following error? It occurs when I try to perform tool changes and even when I am in jog mode and past the 100% on the over ride. The machine has a control technologies control.
    Mark Reuss
    Sep 2009
    We have a 95 arrow 500. We did have the same problem. z drive was running hot. ended up replacing z drive. later we had the same problems again so we moved the z drive to the 4th axis drive area,no 4th axis drive option, since then no problem with z drive. try running machine w/ back door open and a fan blowing in. hope this helps
    Nov 2010
    england
    Usual fault of this type is a tight axis, check the ballscrew and ways are lubricated and remove the covers to make sure they are not jamming up or packed with chips.
  1. Cincinnati Arrow error 9036 HELP!
    By cncwork in forum Cincinnati CNC
    Last Post: 06-03-2013, 09:02 PM
  2. Error mseeage Arrow 750
    By masmith17 in forum Cincinnati CNC
    Last Post: 01-25-2012, 07:29 PM
  3. A2100 Arrow 500 Error help
    By kentsui in forum Cincinnati CNC
    Last Post: 10-31-2010, 01:44 PM
  4. Arrow 750 Error 9178
    By ivanfed in forum Cincinnati CNC
    Last Post: 09-09-2009, 04:36 AM
  5. excessive Z axis slop. Help!!
    By msomerville in forum Milltronics
    Last Post: 10-10-2007, 02:03 PM
