Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 12-06-2010, 06:06 PM
cncatj is on a distinguished road
A2100 Bridge Board Repair
Hi guys , I have a Bridge board that needs a repair ,the problem is that it does not recognized the Floppy drive , already swap to other machine , & the problems goes with the PCB
I might be able to repair it , I was wondering if does any one knows where
i can get a copy of the schematics for this board P.n 3-542-1260A
Thank's
Old 05-03-2011, 04:08 AM
seraum is on a distinguished road
Bridge board
The floppy drive is not connected to bridge board. The floppy drive is recognised by the Workstation CPU. you must enable it in the BIOS, and in the parameter of a2100. in addition you must have this option enabled. In most case, the DNC is much better.
Old 05-18-2011, 03:49 PM
J. R. Williams is on a distinguished road
Bridge Board
Contact Siemens as they offer a repair service for any boards not in exchange stock. Bring money. I recently had the workstation motherboard repaired and that did not solve my problem. I am in the quotation process of replacing the entire system. The bridge board has a card with the system serial number info that may present problems.
JRW
Old 05-20-2011, 07:47 PM
Thank's guys , i send the board to be repaired by the experts
Need repair or c/over siemens board. arob Siemens Sinumerik CNC controls 1 06-30-2010 08:03 AM
milltronics board repair dropem631 Milltronics 2 05-18-2010 05:21 PM
Problem- a2100 rt board failure (again) edsgarage Controller & Computer Solutions 1 09-07-2008 05:18 AM
KTL board repair???? mansuper Bridgeport and Hardinge Mills 0 11-19-2006 08:57 AM
Circuit board repair motordude General Electronics Discussion 2 02-20-2004 10:28 AM
