Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Cincinnati CNC
Cincinnati CNC Discuss Cincinnati CNC machines here.
Old 11-10-2010, 12:30 PM
hawk1 is on a distinguished road
Question CINCINNATI SABRE 750 X.Y.Z AXIS FAILURE
I have a 1994 sabre 750. Have had it for 2 years fighting an ongoing problem that comes and goes.It will be running fine and all of a sudden it will stop and the alarm will usually read" x drive axis failure" and sometimes "x.y and z axis failure".
i've replaced the x drive axis servo motor and cables, ice cube relays.Have had the voltage checked and everything is fine.
The machine has been running fine for 3 months and all of a sudden its doing it again and I cannot run the machine for fear of the head dropping.
I am really getting sick of this problem. If anyone has any suggestions, they will be greatly appreciated. I cant afford to have this machine down too long.
Old 11-10-2010, 01:42 PM
kjtdouglas is on a distinguished road
We have a Sabre 1000 about the same age as yours which we have had from new. We have had the same problem as you and found it is a break in the wiring loom to the "X" axis. We found out when taking the slideway covers off and shaking the cable to the "X" axis motor the machine worked OK again.
So this is a possibility on your machine. I think the cables get brittle over time.
We have now part exchanged our machine and its going out next week.
Regards
Kevin
Old 11-10-2010, 02:36 PM
mallardfizz is on a distinguished road
drive fail
hello
when the problem occurrs can you restart the machine by cancelling the alert and pressing the green start button OR do you have to shut down the machine and isolate it before restarting. if its the latter what lights do you have on the axis drives. i presume its an A2100 control with Kollmorgan drives.
if you have to shut down the machine before restarting it would indicate a drive reporting a problem and one drive should have probably 2 red lights and a green instead of one red and one green.
please recreate the problem and note the lights on the drives. normally when you turn on the main isolater you will have 1 red and 1 green on each axis drive followed by 3 green after the 2nd press of the green start button.
regards
mallardfizz
Old 11-12-2010, 03:37 PM
XYZ Servo drive failure
Thanks for the help... I found that the X drive servo motor cable was in a bind and putting pressure on the connection. Like you said, a little pulling to ease the tension seemed to work. I ran it all day today with no problems.
Old 11-12-2010, 07:09 PM
Great news. Good to see that my first post helped your first post.
Cincinnati Sabre 500 leggetmachine General Metal Working Machines 8 05-15-2011 11:14 PM
Help! with Cincinnati Sabre 750 CNC cgerchow Cincinnati CNC 0 01-13-2010 04:37 PM
Cincinnati Sabre 2000 with Acramatic A2100 Axis drifting and drive overload alarm AlC Cincinnati CNC 5 12-18-2009 04:07 AM
Cincinnati VMC Sabre 750 HTMDGEARY G-Code Programing 8 06-23-2009 11:50 PM
Need Help!- Z-axis problem- Cincinnati Sabre 750 JameyLH Machine Problems, Solutions , Wireless DNC, serial port 0 08-20-2008 11:16 PM
