| Cincinnati CNC Discuss Cincinnati CNC machines here. |
I have a servo motor is 3set,. 1.VFS5 of spindle cnc (cincinnati aroow 500) 1set. 2.BSD4 of X, Y and Z axis. However, current machine does not work. I want to change the new controler, but I had no guide to the wire. And a program for customizing Driver VFS5. Now VFS5 LED. -Active llluminated. -System OK not llluminated. -CPU flashing. -Fault not llluminated. And BDS4 LED. -Control volt not llluminated. -Enable llluminated. -Drive ready not llluminated. -Foldback not llluminated. -Overtemp not llluminated. -Overcurrent not llluminated. -Over volt not llluminated. -Under volt not llluminated. -Over speed llluminated. Note: Connect the motor and resolver of overspeed and power led is still off. Quick Help offline. On thailand. ![]() 53000udom@gmail.com Thank you |
Hello Udom, It sounds like the program is corrupt on your VFS5. A flashing CPU light means the spindle drive is stuck in autobaud. <Waiting to find the correct com port baud rate> Here is a link to the software to communicate with your spindle drive from Kollmorgen. http://www.kollmorgen.com/website/co...2010.SETUP.EXE The communications cable you need is 3 wires, NO more. End to end the com's cable wires as follows. Pins 2-3, 3-2, 5-5 Hope this helps, just IM me if you have anymore specific questions. ! Chris |
| Cincinnati | diazosvaldo | Spanish CNCzone | 0 | 01-29-2010 05:33 PM |
| Need Help!- Cincinnati CL-707 | Benjamin P. | Laser Engraving & Cutting Machines | 0 | 03-20-2009 04:34 PM |
| DNC on Cincinnati FV 750 | DHYSTA | Fanuc | 2 | 02-27-2008 06:30 AM |
| G96 on a Cincinnati | cdlenterprises | General Metalwork Discussion | 1 | 06-14-2007 04:45 PM |
| Cincinnati FTV | yorel23 | General Metal Working Machines | 5 | 04-09-2007 03:24 AM |
